check engine light came on?
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
well i have no idea what is goin on cuz the car didnt do anything, i was just driving and all of a sudden the check engine light came on..dunno what is the problem, the car drove normally, i have an intake on it and when the light came on the temp outside was around 43 degrees , u think the temp might be the prob wit the intake and the airflow sensor??????.....no clue why light came on...
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Did you recently get gas? Check to see if you didn't tighten down the gas cap all the way. Most common reason.
just checked it and it was tite all the way...dis is just wierd ...motor sounds normal...would the light come on if i need to get the oil changed..cuz im like 500 over right now..
Originally posted by jdmaristo
oh yea its at 30000 now do u think that the light came on cuz i havent changed the differential fluid and the transmission fluid yet???
might be a bad sensor somewhere. car feels normal? mmmm doubt its the fluids, but you should change those anyway, 500 over on old oil isnt too spiffy for your engine.
could be one of 3 things
bad o2 sensor
seal around maf sensor not tight giving bad signal to main ecu
dirty maf sensor and /or tps sensor bad
disconnect neg terminal for 15 mins , reconnect and drive normally , if light comes back on , get it checked out
codes wont disappear if you disconnect neg terminal , dealer scan tool can still retreive stored codes
bad o2 sensor
Originally posted by NoRyceGS4
mmmmm i dont think he would be able to turn on the car with a MAF problem.
oh yea i dont have the 400 i have the 01 300,it drove fine today to..like usual...but the light is still on..i havent reset the ecu yet but i will do it later dis weekend when i get home incase something happens..cuz im out of town right now.....do u guys think its a prob easily fixed
Originally posted by rominl
well it's possible. me and another gs400 owner got bad MAF and check engine light came on, and we were still able to drive the cars
yea thanx guyz for the feedback..cuz i never think this stuff can happened to me in the lex..but im at college right now and will get it look at when i get back home.
thanx
thanx
