GS curse strikes the newbie!!!!!! (HELP!!!!)
Although I will leave the explaining of how to do it to someone more knowledgable...
Make sure you THOROUGHLY clean the area affected by throw-up. If not, you will forever hate the person who did so because the smell will linger on and on.
-Anthony
-Anthony
Originally posted by rominl
contact rmmgs4 right the way man!!!
The door panel is not too difficult to remove.
There are about 3 or 4 hex head screws on the bottom of the door.
There is a screw behind the plastic cover under the open door lever.
There is a screw in the middle of that black rubber stop.
mmmmm....there are a few clips as well.
Be careful when removing the door panel....you have to unclip the wiring to the door light.
To remove the panel easier ....lower the window all the way down....the panel hangs on where it meets the window.
Take your time.....its very easy.
on me for not searching first but it was 5 in the A.M. I found bananaGS's site helpful, the DIY speaker upgrade showed me all of the bolts. I am happy to say that I got every bit of the yuck off
Next time I won't drive my car to Dave and Buster's Milpitas
Artvipout
10-11-11 12:09 AM
DixonPai
05-31-09 04:00 PM
erayd8
11-06-02 06:44 PM
