45k mileage coming up...what do i do?
koreanpers, per the lexus owner's manual supplement, for 45k service one should replace engine oil and filter, replace air conditioner filter, rotate tires, inspect the following: exhaust pipes, brakes et al, steering linkages, rack and pinion assy. for leakage, ball joints and dust covers, drive shaft boots, auto transmission and differential oil, and body.
but if your car is classified as running under special operating conditions (towing a trailer or using a camper or cartop carrier; repeated short trips of less than 5 miles in temperatures below freezing; extensive idling or low speed driving for long distances as in heavy commercial use such as delivery, taxi or patrol car; operating on rough, muddy, or salt covered roads; operating on unpaved or dusty roads) you should in addition to the above inspect engine air filter, replace auto transmission and differential oil and inspect body/chassis nuts and bolts.
horacio
horacio
Originally posted by koreanpers
what are the musts on the 45k service? other than oil change? thanks
hey guys, thanks! i went to the local dealer here..picked up a schedule. looks like the only thing needed is oil change (which i just did), tranny fluid change and diff change. have trd exhaust, weapon r intake ( so no inspecting needed there)
Fizzboy7
07-26-10 01:37 AM
