Clear bumper lights
They are very easy install. It took me 10 minutes only because i coulnd't find the 10mm wrench.
You need a phillips head screw driver, and a 10mm wrench. Unscrew the foglights from the front of the car, reach inside with the 10mm screw and un-bolt the side markers. Then remove the bulb assembly from the side markers, and the removable screws(you'll see these when you take the aseembly apart). Take the clear side markers, assemble the bulb mechanism, and bolt them back in place with the 10mm wrench, and voila!
