getting to cigarette lighter
HI,
I want to tap power from the cigarette lighter. I thought I could just pull out the ash tray and get to the wiring, but the unit was sealed. Any thoughts on how I can tap the cigarette lighter? Or is there a better place to get switched DC power under the dash?
Thanks,
jerry
Thanks,
jerry
Originally posted by rominl
you can easily pull the whole ash tray together with teh cigarette light out, right?
Originally posted by Letsride
If you remove the entire tray from the console you can get to the wires. Just grab the ash tray and pull straight out.
1. Remove ash try cigarette dump thing.
2. Grab ash tray assembly, where cigarette repository used to go, not the door
3) Pull like heck.
Results, nothing. The dang thing will not budge. Do they glue these things in?
Originally posted by Neo
In case you did not do it, it is a little easier if you change gears and pull the shifter out of the way. You get a little more space to work it.
Grab the door on either side and pull. Its just 2 clips...
Thanks,
jerry
Yes the whole section comes out and not just the door. Grab the frame actually, at least that's how I got back there.
Originally posted by jboy
OK. BTW, where are the two clips located? I am going to see if inserting a screw driver will help. Thus far 3 people have tried and it has not budged.
RMMGS4 told me that he actually removed the clips since he is messing with his car so much and it still stays in place pretty well.
Good luck.
I verified with RMMGS4 who was working with me when I did some wiring that there are actually 4 clips at each of the corners. They are deep inside though so prying probabaly won't get you much. You'll just have to get all your fingers into the ashtray top, leverage your thumb on the radio panel and pull sharply. That thing will not budge if you pull lightly.
Good luck.
Good luck.
We finally got the thing out. 200+ pound guy pulled really hard! It looks like some sort of seal formed around the edge. There was a white flaky residue on the ash tray part and the console. Might be glue, spilled soda, or a dried up latte. Anyway, now that is out I can wire in the power supply to the XM radio.
Thanks for all your help.
jerry
