2 Oxygen sensors out...No new ones being made??
Old 09-19-06, 05:56 AM
Tammy
Tammy's Avatar
You're right, this is an old thread.
And with it, there are error code given by the OBD II. It describes what and where the code originates. Or, where the part is located.
The O2 sensor was replaced with a dealer supplied part.
Yes, a local mechanic should be able to replace the sensor. It is recommended you use Denso brand.
Lastly, please provide the vehicle's mileage, year and model you are refering to...Your 1999?
Old 09-19-06, 07:21 AM
chuckisc
chuckisc's Avatar
1999 GS300 W 115,000 miles
Old 09-19-06, 07:48 AM
Tammy
Tammy's Avatar
You never mentioned if you have a "check engine lamp" error indicated. If you have this error from the readout ....
P0135 - normally, a problem with sensor 1, bank 1 (passenger side, exhaust manifold)
If more than one sensor is failing, the error would be persented on an OBD II readout.
A recommended web site for the Denso sensors...
http://www.automedicsupply.com/index.php
Hope this helps...
Old 11-13-06, 05:03 AM
chuckisc
chuckisc's Avatar
Thank you Tammy,
Sorry to trouble you one more time, what is the OEM Part# for this O2 Sensor? I went to the link you recommended, not sure which one I will need.
thank you
Old 11-13-06, 07:40 AM
Tammy
Tammy's Avatar
Do you have the P0130-P0135 sensor #1 error or a P0136-P0141 sensor #2 error? The pigtail wire length is different.
One O2 sensor is for the front manifold (cyl 1-3) #234-4048
and the rear manifold (cyl 4-6) #234-4626 on the straight six engine.
http://www.densoaftermarket.com/cata...US&model=GS300
This site may be more helpful, sorry about the automedicsupply.com site.
Old 11-13-06, 11:56 AM
chuckisc
chuckisc's Avatar
Hi Tammy,
Thank you for the detail link. The error I got is P0135.
rolson42
RC F (2015-present)
13
02-22-18 08:06 PM
bmair
09-16-10 06:40 AM
sparks11
67
04-24-09 01:47 PM
archangels
RX - 1st Gen (1999-2003)
42
05-28-08 08:14 PM
MrGQ
Performance & Maintenance
04-05-02 05:09 PM
Quick Reply: 2 Oxygen sensors out...No new ones being made??
