Clunking sound over bumps from front end
#31
Originally Posted by doug_999
Yea, I'm not too impressed with the reliability/build quality on my GS that's for sure. I will say that now that my engine tick is fixed, I like the car a lot better.
My knocking was fixed by lubing the upper mounts - at least that's what I think it was. Tim, if they can't figure it out, have them call Arlington Lexus in Palatine IL and talk to the service manager - reference me (oh and they know me alright) and they can tell your guy exactly what was done.
#32
Well, I think I can finally put this to rest. Clunking fixed by replacing entire spring/shock/strut assemblies both sides. Squeaking/scrunching sound finally ID'd to the sway bar pillow bushings. Quiet as a mouse now.
#35
I having a similar problem as some of you described with my 2001 GS300. I get a knocking (sometimes rattle) sound from the front end when I go over small bumps, I'm almost sure its coming from the right side. The funny thing is that it only happens when its cold outside, anything over 70 degrees and the sound is totally gone. Did anyone have the same problem, or or does anyone know what the problem could be? From what i read I'm gonna get the sway bar and ball joints checked. Thanks in advance
#36
#38
Yes, mine was that the upper mount needed to be lubed or something like that. This was after my entire strut was replaced several months earlier.
#39
Thanks doug999... I've had my suspension changed to H&R and Bilstein shocks, and i still get that clunking sound over bumps.... i also notice that as the car warms up from being driven, the clunking tends to go away a little or get quieter. Did the same thing happen with you? If this was the same problem as yours, and if it is the upper mount.... you have no idea how much i will appreciate your help... this noise is driving me crazy for 2 winters now and the dealer is no help at all.
#40
Yes, mine was only occuring in the winter months. The problem was that I never got a service ticket so I'm not sure exactly what they fixed. If you are interested, I will give the dealer a call and find out exactly what the repair order said.
#41
I got my clunking diagnosed to be the sway bar link. Could someone confirm that the first number listed on the diagram in post #14 of this thread is the torque to tighten the bolt to?
Thanks a lot.
Thanks a lot.
#42
Thanks Chuck, but the numbers for torque shown on the TSB don't match any of the numbers on the corresponding bolts that are shown in the previous post (#14).
I'm trying to get the torque specs for the link bolts. Any ideas on tnat spec?
#44
![](https://www.clublexus.com/gallery/data/500/medium/rear_sway.jpg)
![](https://www.clublexus.com/gallery/data/500/medium/front_sway.jpg)
#45
