Fast Blink Right side turn signal
When I use the right turn signal the light in the dash as well as the exterior turn signal lights on the outside blink fast. The owners manual suggests a bulb is burnt out however both the front and rear turn signal lights appear to be lit and blinking. Any suggestions?
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Originally posted by Letsride
Could also be a bad relay.........
If the turn signal flashes fast you should first see if a bulb is burnt out. If none of them are burnt out then your relay needs to be replaced. Now as to where the turn signal relay is on a GS, I have no idea, but I do know they are usually very cheap and easy to replace.
Is this problem only present on one side? If everything blinks normally on the other side, then it can't be a flasher relay unless you have one relay for each side (which I doubt).
Do you have any indications that a bulb is out? If NOT, then this is very strange indeed.
Please let us know what you find out.
GSEREP1
GSEREP1
GSEREP1
GSEREP1
Master Thread Closer!!
leebarroll -
I know you got a GS...but there's a TSB for the ES for this same issue.
https://www.clublexus.com/index.php/...ew/2154/1/115/
Good luck, bro.
Pete
Good luck, bro.
Pete
sleepybobcat
03-02-02 02:34 PM
