the toys are here
phluid - yeah I've got the K&N FIPK2 intake. I love the sound. I think the SAFC-II should help match the air flow with the fuel, much like the SRT piggyback ECU does. I plan to get the SAFC-II 'tuned' at a local shop.
Switching subjects... anyone know how to get the ashtray out of the console? Not just the inner 'ashtray liner' that comes out of the retractable 'door', but I mean the whole thing? I think I want the SAFC-II display in the ashtray. Someone asked if it has a harness or just bare wires to solder in. A quick look in the box makes it look like it has both. ?? Also, ALL the instructions are in Japanese, so I plan to print the English manual online!
Finally, I'm wondering where to mount the EDFC 'box'. Only place I can think of it under the steering column. Only concern with that is it has vents in it and those might be blocked or directly in front of the steering column air vent which wouldn't be good if it's blowing hot air!
I know someone did that awesome install above the park brake but that looked like MAJOR work.
to get out the ashtray alls you have to do is open it and pull it has clips holding it in place dont be scared to give it force i yanked mine out of my old gs300 and it popped right out and went back in no problems !!! there is a plugon the back of the ashtray just unplug that and its out !!!!
Originally posted by phluid
I had to put my keys in the ignition and move the shift **** back so that I had space to pull it out.
Just get a little leverage and pull. There are 4 clips and they are in there pretty tight. It gets looser with each removal but the first one, you have to give it a little elbow grease. Like lv2000 said, there is a plug attached behind it though.
The EDFC above the parking brake was RMMGS4, I think. He always does nice work.
Northern California Regional Officer
Options, Options, Options
Bit,
you might wanna consider mounting under the steering column like you described and then leave enough slack in the wire so that you can move it above the brake lever, given that there is a remote possibility that I might sell knock offs of my bezel in the distant future. Neo has mounted his EDFC in this fashion, as he is first in line for one of my knock offs.
The problem (as you may guess) is that I am swamped with several projects.
PS - which do you want done first, the EDFC bezel release or the IS 300 pedal conversion?
I am working on the latter as we speak.
