my new mod (LTuned shocks, Tein Springs)
my new mod
wel i just installed my ltuned shocks and tein springs last night it sits pretty low ! so low i had to roll my fenders in the front on my passenger side it makes a noise over any bump ,so tomorrow i am pulling it apart again !!! to fix it here is a pic more to come also anybody know what that noise could be i pulled it off earlier and made sure everything was tight and still makes noise i think the spring is not in properly look at sig or before shots
also i ordered a l tuned steering ecu ( is it red ? ) and i have a srt intake on its way ( thanks tlex ) trying to contact srt for the ecu and still looking for a borla exhaust ! this mod bug is getting expensive !
Master Thread Closer!!
Re: my new mod
Originally posted by lv2000
[B... my passenger side it makes a noise over any bump ,so tomorrow i am pulling it apart again !!! to fix it here is a pic more to come also anybody know what that noise could be i pulled it off earlier and made sure everything was tight and still makes noise i think the spring is not in properly... [/B]
Check out my old thread....it may help with the noise issue.
https://www.clublexus.com/forums/sho...hlight=springs
Btw....I pm'd you on the Ltuned-like tips.
Peter
also , its a bad idea 2 try useing the intake without the ecu....
Looks real good man, aggressive and has a slight rake. That thing is gonna be a sled once they settle!!! LOL
I thought the TEIN would be to low from its advertised 1.8 drop, but it looks good! I bet it looks lower in person too!
I like the simple design of those wheels, they go well with the lowered look!
Post more pics in about 2-3weeks once she settles!
Just curious. Did you use the stock bump stops or the ones L-Tuned provided?
i used the factor y as tein book stated and cut 1/8 off it rides awesome my old shocks were worn and it rides nicer lowered !!!
lets ride how are those pics ??? my dig camera sucks i will post more when i can get a good camera still shopping
jucee187 that looks good.. u have any closer shots? and how many finger gap did it end up being?
and what size are your rims and tires?
Thanks
my rims are 20 x8.5 and i believe a pinch under 2 fingers i really pinched my finger
wait u bought the srt intake without the ecu? unless they decide 2 d it 4 u they won't sell u just the ecu, i tried a while back.. i had bought the intake without ecu from a member who lost it and when i called i think i spoke 2 mo or someone else and they tried 2 get it 4 me but later told they could sell just the ecu 4 the intake..better look into this sooner than later buddy....
is that bad bluelex ??? i thought it would work like the fipk but look different ??? an intake should help alittle right if not it should sound good
Thanks
4 some reason the srt inrtake was made 2 work with its ecu, its says cleary not 2 try one without the other..mayb cus it allows more air flow than other intakes cus its bigger and the engine might mot respond right thinking its a problem ....i remember even asking this 2 mo at srt and they told me not 2 try it ...b careful dude.. the srt intake is 3.5" wide where as normal intakes r 3".i guess it makes a difference...
