GS300 vs. Passat Question
Hi, I own a 2001 VW Passat and have been pretty happy with the car. My friend is selling a 1998 Lexus GS300 for a good price. I am considering selling my passat privately and buying the lexus because the money I wil have left over I can use to pay debts. The Lexus also has more power. What I wanted to know is whether the Lexus will cost much more to maintain than the passat? The lexus has 90,000 miles and my car has 24,000. Since Lexus has a better reliability record would it cost less to own, or are Lexus parts so much more to replace?
Thanks,
Dave
Thanks,
Dave
No answers? From my experience on a 99 GS300 with 96k, no problems AT ALL. Parts $ are about the same at Toyota, not marked up b/c it's a "LEXUS" unlike BMWs and MBs that are about 3x as much. Only regular maintenance and oil changes every 3k for me. You will have no regrets.
Guest
Posts: n/a
Yeah, VW warrenty is what 24/2. Once your friend maintened the car, it will be trouble-free for you.Lexus is the most reliable car new AND after 5 years of ownership. I believe the GS is the most reliable car in it's class according to JD Power. THe Passat is a fine car and the GS 300 is a wonderful step up from it.
Thanks,
Dave
Thanks,
Dave
40K miles: busted valve gasket $450 (covered by warranty)
50K miles: busted vacuum hose, check engine light went on $260 (out of pocket)
30K - 90K miles:
4 lights go out (head, interior); oil leak; changed front brakes 2X and rear brakes 1X ($300 / brake job) ~ mandatory rotor change with pads.
*here's the doozy*
92K miles: ABS control module, or speed sensors, or intrument cluster failure: The reason why I say OR is because of the horrible service from the dealership. They could not pinpoint the problem and could only suggest to repair one thing at a time, to fix the problem. To fix all these problems = $2,400.
so I decided to part with my Passat and move "up" to a GS300. A vehicle I wanted for a long while.
I was very pleased with the performance of my car, especially with the suspension and wheel upgrade I did to it. ALTHOUGH, it did not off set my distaste for the lack of reliability and very poor customer service.
VW v. LEXUS = night and day
Although I've had a couple setbacks with the door actuator and the master brake cylinder (both covered by warranty), these are the only true known defects in the GS aside from a throttle position sensor.
BUT the service is superb, bar none and after most of the typical GS problems are now fixed, I am looking forward to thousand of miles with smiles.
If you have any questions, PM me, btw as far as the power goes, I had a 1.8T and it's nothing compared to my GS. I love it.
Also, are you a memeber of clubb5.com, you can find alot of info about Passats specifically. It help me get through all my woes. A pic of my ride is on it to. I have the same user name.
My suggestion: get the GS, get the cash, and run. You can't lose.
