What's a good battery brand?
Old 02-27-01, 07:08 PM
Dazz5627
Dazz5627's Avatar
Post
Just got my system installed today. I'm running a 700 watt amp with 2 12" Punch Comps. I must say that the stock battery is not holding up. All of my lights are dimming pretty bad. What's a good brand to get to replace the stock?
Man, when I had my TL, there weren't any probs. with the stock batt. What's up with that?
Old 02-27-01, 07:33 PM
superlexus
Guest
Posts: n/a
Default batteries
lexus batteries have a little history of problems, i dont know much about that but i think it would be wise to replace it.
Old 02-27-01, 07:56 PM
LexusRules
LexusRules's Avatar
Angry My Batt Sux too!
Lexus need to upgrade on the battery size! When i got my subs in my GS we had some battery problems, battery would die, and its a pretty crappy amp! My dad's LS400 has had a bad battery all its life, dying out and stuff. I suggest that (in an ideal setup) you get a stiffening cap, new battery (a HUGE one), and a new alternator. I can't afford any of these options, hopefully you can.
Old 02-27-01, 10:48 PM
GlobeCLK
GlobeCLK's Avatar
Cool
what about Optima? Supposed to be really good batteries?
Old 02-28-01, 11:06 AM
badmuthrfkr
Guest
Posts: n/a
Get an Optima Yellow top. 700CCA. It is a deep cycle battery. I used to have a lot of dimming problems on my Pathfinder, I'm pushing a good 700watts rms. Should be $180 at your local Batteries Plus.
Old 02-28-01, 11:22 AM
Dazz5627
Dazz5627's Avatar
Thanks for your replys. I'm gonna go get an Optima brand this weekend...Hopefully, that'll cure the problem.
Old 02-28-01, 12:50 PM
gadgetSC
gadgetSC's Avatar
Thumbs up Battery
Optima is the way to go!
Old 03-01-01, 01:10 AM
Mean Gene
Mean Gene's Avatar
Thumbs up Optima Yellow Top
Dazz - Yep, get the Yellow Top & consider adding a 1 farad stiffening cap to your bass setup. It'll add quicker response to those rapid bass transitional notes where the battery itself can't keep up. U won't need a bigger alternator with your current system so save that money. Didn't U have a post on the old Forum about being left stranded in downtown Houston a few months back with a bad battery or do I have ya confused with another member?
Old 03-01-01, 05:03 AM
LexusRules
LexusRules's Avatar
Question I also have this problem
i also am having this problem, but when the stereo is off and i just rev the car a bit to charge the battery it still dies! could the cold weather have anything to do with this? how will a stiffining cap hold the battery's charge? will a bigger battery be all i need?
Old 03-01-01, 09:29 AM
JBrady
JBrady's Avatar
You guys have me worrying about my battery now. I have 70k on the 96 LS and it has a Lexus battery. I bought the car Certified with 50k so I can only guess if it is the factory original. Have had ZERO problems. What is the average Lexus battery life everyone gets?
Old 03-01-01, 10:04 AM
Dazz5627
Dazz5627's Avatar
Default Re: Optima Yellow Top
Thanks for everyones replies. Yeah, I'm gonna go get the yellow top this weekend. If that doesn't help much, I'll try the stiffening cap. And no, that was not me that got stranded. I just got my Lex a week ago.
Old 03-02-01, 02:06 AM
Mean Gene
Mean Gene's Avatar
Unhappy Cap Won't Help Your Battery
Sasha - It sound like U have a weak/dying battery or a bad alternator. Go have them checked at a reputable shop or borrow a tester that applies a load to the battery & DIY. Can also put a metter on the battery with the car off & again with it running - should have 12+ V off & 14 V while running. If it's below 12V when off, your battery's weak & if it doesn't register 13+ V while at idle, your alternator may be going out. The stiffening cap will only help your stereo when the bass notes - it has nothing to do with your car's charging system. Also, yes, cold weather will make your battery's weakness more easily noticeable.
Old 03-02-01, 10:10 PM
bmm89
bmm89's Avatar
So i assume an optima yellowtop will fit???
Also, where can this battery be found?
Any good places in particular?
Old 03-02-01, 11:35 PM
VeilSideGS3
VeilSideGS3's Avatar
Thumbs up
I have the Optima Blue Top 900m. This battery is great and is the top of the line Optima battery...for now.. :P but the yellow top is also great as well...
Kirb
Old 03-03-01, 03:58 PM
GSBob
Guest
Posts: n/a
Optima rules. Anyone...what are the deminsions of the Blue and of the Yellow?
Quick Reply: What's a good battery brand?
