Lower door panels
Old 03-14-04, 07:32 PM
EmeraldLexuSC3
EmeraldLexuSC3's Avatar
Post Lower door panels
Is it possible to remove the exterior lower door panels (highlighted)?
And if so, what are the steps?
Old 03-14-04, 07:47 PM
Winter GS
Winter GS's Avatar
I did this last night ( The wife opened the door on a HIGH curb and it cracked the rubber thingy at the bottom... It is very easy just make sure it is warm so you dont break the plastic clips. You have three black nuts to remove they were 10mm then take a screw driver with a small towel around it and pry slowly @ the bottom. It should all them just come off.
Old 03-16-04, 08:09 PM
JunctionGS
JunctionGS's Avatar
winter gs is right. Few bolts and the rest is held on by clips. Just take your t ime.
Old 03-16-04, 08:24 PM
EmeraldLexuSC3
Post
The procedures sound easy enough.Thanks for the info guys!
Old 12-05-04, 11:51 PM
ShowDiscipline
ShowDiscipline's Avatar
Does the inner door panel have to be removed to do this?
Old 12-06-04, 12:04 AM
TAMR_GUS98
TAMR_GUS98's Avatar
Post Removing lower cladding.
ShowDiscipline,
Inner door panels stay on. Just remove the black 10mm nuts and the rest is held on by double stick foam and plastic clips. You can also look at the new one and figure it all out. It's easy.
Will
Old 12-06-04, 01:33 AM
rominl
exclusive matchup
rominl's Avatar
Default Re: Removing lower cladding.
Originally posted by TAMR_GUS98
ShowDiscipline,
Will
yup, i have seen them replaced before and the inner door panel stays. the 10mm bolts are at the bottom, and the piece is held on with tapes and clips. i think the tapes are what keeping the panel on pretty tight
lexforlife
Performance & Maintenance
02-22-17 05:50 PM
sallydrive
08-14-12 07:27 PM
vwynn
04-10-09 09:14 AM
Baybarea
05-17-07 04:20 PM
erayd8
11-06-02 06:44 PM
Quick Reply: Lower door panels
