*HELP* broken door locks?
pass. side front door no longer works when pressing lock on the key...all other 3 doors work fine. is this the ''common'' door lock problem i've heard about? if so, whats the fix? i'm hoping something i can do myself. thnx fellas...
If your out of warranty prepair to get it good, I checked with lexus the other day, 290 for the actuator, 200 labor. The guy told me on the phone that you might wanna check some junkyards. You can order it from steve ganz for 198 i've heard
Before you go through all of this.. check to make sure you didn't blow a fuse first.
I had the same problem and it was a simple fuse problem. It's worth the look.
-Anthony
-Anthony
