Question about ground clearance after 20's and L-tuned springs (1" drop).
Doing simple math in my head, is it about accurate to say that my GS with the stock 17's will have about the same ground clearance when it's on 20's w/ a 1" drop?
figure the 20's add 3 inches of clearance, but I'll be running small series tires than stock. Add that to the additional 1" of drop and it should all about even out?
Any input would be appreciated. Thanks!
- Patrick
- Patrick
The One
That's about right. The L-Tuned will actually drop a little more than 1" in the front but then the 20s with 35 or 30 series tires (depending on what width your rims are) will have a bigger outside diameter than stock. You will probably have slightly less clearance but not by much.
The One
Originally posted by lex01
I have 19" rims with 35 tires. How much should i drop to make it like normal? And what is the max. inches that i can drop?
whitels
Suspension and Brakes
10-09-02 04:13 PM
