Squeaky noise from the timing belt
#31
Master Thread Closer!!
Re: GS300 serpentine belt removal
Originally posted by SeattleGS400
GS300 V6 serpentine belt removal
Similar instructions as above for the GS400, but for the V6 GS300, loosen the belt tension by turning the drive belt tensioner clockwise, and remove the drive belt.
See the following pulley schematic for the GS300.
#32
Reviving this thread because I'm getting ready to change the belt on my 99 GS400. I'm not clear on something. When I put a wrench on the tensioner pulley bolt, am I loosening the bolt or just moving/rotating the pulley against the spring tension to lessen the tension on the belt? Thanks.
#33
just thought that I would clear that up
#35
You're not loosening anything. What you're doing is moving the spring loaded tensioner pulley arm to take the tension off the belt. When you release it, it will spring right back.
#36
Former Vendor
Thanks Fasted - I dropped the car off at the dealership for an oil change and they found the problem. It wasn't the belt, it was the drive belt tensioner. Got quoted for a new drive belt tensioner, belt, timing belt, and all labor for $600. I'm thinking about having them replace the water pump while they're down there... thoughts?
acarapella
20
01-12-18 06:06 PM
jcho11
11-30-17 07:43 AM
