How to replace chrome strip on driver's door
Hey guys. I figure someone must know the answer to this. The chrome strip that runs along the inside top part of my driver's side door has a bunch of small dents in at (don't ask, because I have absolutely no idea how they got there). I would like to replace it. I tried to remove it, but I just can't seem to get it out. Does anyone know how to remove the strip? Do I have to take apart the door? Thanks in advance for any help.
e-man
e-man
Here's a close up look at it. I really couldn't get the dents to stand out, but there are about 15-20 of them and they run along the entire strip of chrome. I'm thinking it might have happened when the first owner had the tint put in, but I really don't know.
Search Function Inc.
Tske off the door panel. The chrome strip is attached to the door by pins that you can get loose. Those pins are a part of that chrome strip. Kinda easy when you take out the door panel.
yeah if you take off teh door panel it's pretty easy to take off the strip, i just hope you can get the strip separately.
there are couple of screws all around it. then pop the cover on the door handle, another screw inside. look down from below the armrest, another screw. slide out the front tweeters covers, and you shoudl be able to slide out the panel
Thanks guys. Before I start taking apart the door, I will check with Lexus to see whether that strip is sold alone as a single part. I can't imagine that you'd have to replace the entire door panel to replace that strip, but I'll find out. Romini, thanks for the instructions on how to take apart the door.
For all of you who are interested, I went to Lexus today to check on buying the chrome strip. Apparently, it is sold as part of the door panel (more than $1,000). Does anyone know if there are companies that make aftermarket parts for these kinds of things? I really don't think it needs to be a Lexus part. As long as it looks the same and fits well, what difference does it make.
