Modified Trunk Springs
Old 07-08-04, 08:01 AM
pat14lee
pat14lee's Avatar
Has anyone installed the gas type shocks that are used to prop the hood up? Most luxury cars seem to have these in the trunk too, so I was curious.
- Patrick
Old 07-08-04, 12:14 PM
rominl
exclusive matchup
rominl's Avatar
Originally posted by Neo
When I added a wing, I tried the stiffer positions but it still was not strong enough. Luckily, my bodyshop anticipated this and got me a set of the stiffer tension rods.
that's some awesome thinking there!
Old 07-08-04, 06:32 PM
Received 2,466 Likes on 1,618 Posts
Originally posted by jtanoyo1
Will this mod get rid of the honda-tincan feel that I feel everytime I open the trunk? It feels darn light to open and even with a minute force, it always feels like I am slamming the trunk a lil too hard. I want mine to open nice and slow like my Bimmer and when it closes, I want it to close with a resounding confident thunk. Help!
To improve the sound of the trunk close just put some sound dampening material in your trunk, either on the bottom (wheel well is a good place to target since it's an echo chamber basically), or on the underside of the lid (yes, makes the lid heavier which might not be good given the spring situation this thread is about!), or both.
Old 07-08-04, 10:38 PM
rominl
exclusive matchup
rominl's Avatar
good suggestion, that's what i would do down the road
Old 07-09-04, 09:45 AM
RMMGS4
Northern California Regional Officer
RMMGS4's Avatar
Default Re: Re: I DID NOT KNOW THAT
Originally posted by rominl
i know about the problem coz' rmmgs4 has the same problem and he also drilled another hole
Yup I drilled a hole in the exact same place. One of the first things I did when I bought the car 3 years ago when I nearly took off a finger . Too many mod's so little time to post .
Struts would be nice, but you have to have a very strong mounting points in the trunk and on the trunk arm, plus finding the right length and the strut pressure, all have to be factored in. You could find yourself trying a bunch of lengths and pressures before getting it right. I am doing this exact mod on the wifes IS, BTW and the front hood already has it done, since IS's come with yucky hood props
Old 07-09-04, 06:29 PM
DPGS430
DPGS430's Avatar
I also would be interested in gas shocks for the trunk. With my system, the only thing vibrating now is those friggin rods used for the trunk lid.
Jim
Old 07-09-04, 06:41 PM
Why can't you just wrap them in something (brown bread, dynamat, etc. or even just household insulation or even saran wrap)?
Old 07-09-04, 06:50 PM
DPGS430
DPGS430's Avatar
Tried that, the center support where the 2 rods rest in that plastic piece will not hold a "wrapped" rod. Until I can figure out how to port my 2 Solobaric L7's up through the rear deck I have to deal with it. In the future I will most likely swap them out for a pair of 12's that I can build a ported enclosure that won't require 4-5 cu ft.
Jim
Old 06-08-06, 04:11 PM
jleedog
jleedog's Avatar
Jim
Are the rods supposed to be in the center support? I never really paid attention to them before but this weekend when i was hawling stuff out of my trunk, i noticed that the two intersecting bars are not in the center support grooves. What does that center support thing do when i put the bars in? Should i put them into the grooves?
Currently the two bars are resting just above the center support but not "in it".
i also feel like my trunk tension is weak sauce, but i'm assuming i have the "stronger" tension bars as stock since my car came with the Sport Design spoiler.
thanks in advance,
jason
Old 06-08-06, 04:43 PM
bighitbike
bighitbike's Avatar
Nice mod..If I ever have any spoiler problems i will definately give this a shot!
rhwimmers
12-25-08 12:07 PM
lexluger71
07-19-07 05:42 PM
slickgt1
12-08-06 10:26 PM
sbgs400
10-05-06 03:16 AM
gr8330
06-19-02 06:34 AM
Quick Reply: Modified Trunk Springs
