2001 gs taillights
Old 08-11-04, 11:46 AM
DASHOCKER
DASHOCKER's Avatar
Default 2001 gs taillights
I HAVE A 1998 GS400. WHERE CAN I ORDER THE NEW STYLE TAIL LIGHTS THAT APPEAR ON NEWER GS'S FOR CHEAP? ALSO, IS IT A DIRECT FIT, AND DO I HAVE TO PURCHAS YELLOW TURN SIGNAL BULBS IN THE PLACE OF THE 98'S WHICH USE ALL CLEAR BULBS?
Old 08-11-04, 11:51 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,309 Likes on 1,408 Posts
Hey shocker, how about letting up on the caps lock please?
It is a direct fit.
You need to buy a entirely new piggyback wire for the new lights that will just plug into the new light and old connector. You do not need yellow bulbs, the OEM new lights are yellow just like the old ones. The clear ones you may have seen are aftermarket by Junction Produce and you will not find those 'for cheap' anywhere.
You can look for them in the CLubLexus classifieds or go to one of our vendors like Steve Ganz / www.l-tunedparts.com. They often offer them in group buys for our members (not one going on right now however).
Old 08-11-04, 11:53 AM
TCM080903
TCM080903's Avatar
btw, this is the IS section, right?
you might want to check out the GS section for more info...i'm sure there's plenty of stuff in there!!
Old 08-11-04, 12:02 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Here is the new style light, note the only clear part is reverse.
Comparison of old style lights to the new ones for wiring / bulb placement... the old style is the one with the wiring pigtail on it. I used the wiring on the newer ones on my JP tails.
And finally...
Right click and save as here for a DIY on replacing the tail lights.
http://www.somniplex.com/Dex/Dex%202...ght%20swap.pdf
Old 08-11-04, 12:28 PM
DASHOCKER
DASHOCKER's Avatar
Where can I purchase the piggy back wiring?
Old 08-11-04, 12:30 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
From your local Lexus dealer, about ~22 each I think. The GS430 lights Steve sells to our members typically come with the pigtails the new lights (ask to be sure) so you don't have to worry about it.
Old 08-11-04, 12:51 PM
gserep1
gserep1's Avatar
Default CARSON TOYOTA HAS THESE LIGHTS
Carson Toyota wants $310.00 a set for the lights. Give them a call if you need them.
GSEREP1
Old 08-11-04, 01:53 PM
1niceride
1niceride's Avatar
If you buy them from Steve@Carson , it comes with the wiring needed. Plug and play .
Old 08-11-04, 05:56 PM
rominl
exclusive matchup
rominl's Avatar
yes if you get the taillights with the harness you are all set. mayb eyou can talk to carson toyota and see how much they charge
Lettuce
Lighting
01-30-08 04:53 AM
G Star
Lighting
02-01-06 12:02 PM
DaveGS4
Lighting
15
08-06-04 12:52 PM
flossn
RX - 1st Gen (1999-2003)
18
05-29-03 08:17 AM
mjr24
SC- 1st Gen (1992-2000)
09-06-02 08:09 PM
Quick Reply: 2001 gs taillights
