View Poll Results: will blue98gs3 be able to clear 2001+ taillights
yes......yes he can
27.78%
no....no he can't
25
69.44%
maybe...It's like winning the lottery!
2.78%
Voters: 36. You may not vote on this poll
Will Blue98GS3 be able to clear 2001 taillights??
#62
Originally Posted by whytry
I even went back to check to make sure I did not get the members confused.......
Trying to find a better way to get clear tails, got me all flustered!!!!!
Yeah thats bluelex. Well me and josh figured a way to cut out the 2001 orange lights with a very fine cutter, but to fill it in and it look as good, well i just dont think it will happen.
#65
I'm not quite sure what is that makes JP "whiter" since I can' t see the inside? Have you tried painting the inside white, using mirrors or reflective tapes...........?
#66
Northern California Regional Officer
Originally Posted by GS3Tek
At least you got the cutting part down. I have access to a laser cutter and was going to try this when I have a chance.
2. You'll need to find a way to remove the lense from the housing if you just want to cut through the lense. A laser cuts through EVERYTHING in its path. JP cuts the lense with a laser BEFORE the tails are assembled for the very first time. Everyone else has to un-glue the lense before they can cut it with a laser.
Please don't take my comments as discouraging negativity. I'm just into providing a reality check.
#67
1 Post
Originally Posted by RMMGS4
1. How are you going to program the laser to cut exactly between the amber and the red? There is a ridge of red lense going "ALL THE WAY AROUND" the amber/clear portion. It's a lot more work than just a straight line cut.
Sounds like you haven't seen a real JP in person. The JP lense is just clear, so you can see inside the chrome housing, the bulb, everything without any obstruction.
#68
Just thought that I threw in the laser cutter to maybe help blue out if he ever wanted to do mass fast cutting
Nope, never seen a jp tail, barely 1 or 2 gs with even l-tuned sides
#69
#70
Well, I was thinking you might respond that you have a "good" connection with the laser cutting. If you knew someone who has access to a laser and could program it to cut in a 3 axis motion, you would make a lot of friends on CL.
What could you do with the 3 axis that needs cutting for?
#72
OMG, hope people don't buy em.
If I ever see someone with those tails I'll be moved to shout out " Nice Honda, almost looks like a Lexus !
