Took a turn in the rain a little too fast
When I came out of the turn, as my passengers were pinned against the windows, the traction control light (SWIRVEY LINES) was blinking as I would expect but there was a beeping noise I had not heard before. What was it? or was it the radio? What great control around corners, I never felt anything from the car telling me not to take it faster.
Guest
Posts: n/a
That beeping sound has saved my butt many times.
What is the difference. Is traction for a spinning wheel or wheels while VSC is when the car is starting to move in a direction other then where you have the front end pointed?
Guest
Posts: n/a
Test it out in an empty wet parking lot.
Originally posted by 1SICKLEX
I want to say traction control is low speeds and VSC is at any speed.
The beeping sound is letting you know the VSC is active. Traction control and VSC are different. VSC is the button on your center console on the wood by the armrest. It is always on if you don't de-activate it. Everytime you start the car VSC is on.
If the VSC light blinks, that's just an early warning; but if it beeps at you , that indicates you probably screwed up big time and you would of lost the car if VSC were not on. Trust Sick on this. HE KNOWS !
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
The IS models have traction control, so that only controls rear wheel spin, but VSC (Vehicle Stability Control) does much more. The VSC is activated through several different sensors on the car. It will kick in if you spin the rear tires going straight, or if one tire loses traction while in a turn, but it will also kick in while cornering at high G forces.
I know this because I got the VSC to beep at me for over 5 seconds doing 110mph in the turns of the high banked oval at California Speedway driving a stock GS430.
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
Traction control is for when you forget your anti-perspirant.
VSC is for when you're not wearing brown pants.
VSC is very hi-tech and special on Lexus vehicles. You have to be REALLY pushing the car (at unsafe speeds almost), or the conditions have to be VERY slick for it to come on. There are various sensors inside the car that look at the position of the throttle, the position of the steering wheel, speed, yaw and determines when a spin is inevitable. So it will reduce power to the speeping wheel, and automatically apply braking force to the others wheels to prevent a spin. It works, very, very wheel. The VSC in the GS400 works good. The VSC in the RX300 is outstanding. Even in snow, I was unable to fishtail. It's impressive indeed. And as others have said, the GS can be somewhat of an unruly beast with the VSC off. So keep it on, just in case..
I have heard the beep when I got sideways on off camber wet turn, only going about 25mph. I felt in control but a girl or bad driver or something might have freaked
01gs430
01gs430
01gs430
01gs430
Ever notice when rain hits you see a bunch of Camaro's & Mustangs off the road, usually facing backwards at the exit of a turn?
You'd see a bunch of GS's like that too if they didn't have VSC.
I drove a 325hp five speed mustang 1985 lx 5.0 for years. I don't need no stinking trac control. I love getting sideways.
Anytime I plan on getting on it, I turn off the vsc button. I find it annoying when trac ctrl kicks in.
But for grandma(or my wife), it may be a different story.(How many grannys do you think drive 430s?)
.....i love turning mine off in the snow.....but its getting expensive buying new pants every day.....
