help!!!!! (problem after cleaning throttle body)
help!!!!!
Well i just cleaned my throttle body. and checked my plugs.for some reason when i turn my car on the rpm will jump from1000 to 2500 rpm then fall back down to 1000 then do it agian. i have checked all connections and hoses throttle cable and no bolts are missing what the hell could this be. if you could please help me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Originally posted by TRULUX
no check engine light is on. i tride to drive it but when i shiffted it was a grinding noise and big jerk so i put it back in park without moving.should idrive it i just reset my ecu when i finishedthe throttle body
Unless someone here really knows, it sounds like you might have to get your car to a dealer ASAP.
How did you clean your throttle body?
well i drove it up to auto zone to have the thing checked and it was the throttle body sensor. i thank you for all yalls help, what a drive could not go over 25 mph but it had to be. i think the grinding was because my rpm was to high it only has 70000 miles on it and very well taken care of.so i hope nothing is wrong with my tranny. but i will replace it asap so i will let yall know.once agian thank you for your help.
i cleand it the normal way in took it off used throttle body cleaner and wiped off the tuff stuff but nothing out of the ordinary
i picked up the senser at sewell lexus in fort worth.what great people i called them they said they had it in stock so i drove over there. i get there and they dont have it.what the hell. but they do the next best thing. they grab a new throttle body(they cost about 1000)take the senser off and ask if i want that one.well hell yes iwill use that one. now they put a little white dot on the screw so u know if it has been removed. so at the price of 104 and some change i get my part. drove the g35 home put it on and every thing is great. i also did my spark plugs tranny drain and fill and oil change. thanks for your help
Excellent Trulux - very glad it all worked out! The ups and downs of being a car enthusiast, huh?
Cp2295
11-26-16 12:24 AM
Cure
Performance & Maintenance
08-08-14 09:04 AM
articmonke
05-21-13 08:40 AM
