90k Service
hi guys,
My 99 GS300 is coming up for its 90k service and I am wondering what exactly is entail or needs to be done, there was never a major service at 60k so I know the timing belt will have to be change, is their any place I can look up to see the exact list of items i need to change.
here ya go fellow jerseyan
replace:
engine oil and oil filter
replace timing belt(except ES300)
replace air filter
replace coolant
replace brake fluid
replace air condtioner filter
rotate tires
road test vehicle
inspect the following:
drive belts,fuel linesand connection, fuel tank, vapor vent system hoses fuel tank band and fuel tank cap gasket
exhaust pipes and mountings
brake: linings discs hoses
steering linkage
rack and pinion assy. for leakage
ball joints and dust covers
driveshaft boots(retorque flange bolts)
transmission and differential oil
body
90k mile service
and all services are in the manual
if you dont have your manual
lexus will send you out a free one
just log on to lexus and its there somewhere
good luck johnny
replace:
replace air filter
replace coolant
replace brake fluid
rotate tires
road test vehicle
steering linkage
body
90k mile service
good luck johnny
