HELP: Lugs are on too tight? Any tricks?
I was just in the garage busting my a$$ to get the lugs off so that I could put my new rims on and paint the calipers. I tried soo freakin' hard to loosen those lugs and got nothing. I tried so hard that I (dont laugh) knocked the car off the jack! The lugs are on so tight that the lug wrench BENDS when when I put weight on it - still no leeway.
Any tricks?
Thanks in advance.
Any tricks?
Thanks in advance.
Darius
word of advice bro....DO NOT LOOSEN THE LUGS WHILE UR CAR IS UP ON A JACK....!!! ARE YOU CRAZY? haha okay now that I got that out...
car doesnt need to be up on a jack when ur loosening.
cross bars are great for when the lugs arent on so tight, but in your case use an "L" lug wrech....(those usually come with ur car) then also use a breaker bar: a breaker bar is usually a long pipe that will go over whatever device you are using to loosen a bolt/lug, in this instance...your lug wrench...
basically you just use it to provide more leverage which increases the amount of torque you use to loosen the bolt/lug.
while you are doing this...try to watch what you are doing carefully....otherwise you may snap off a stud and then you will truly be SOL....
g'luck dood...be careful with the breaker bar.
OMG! i didn't realize u said it was still on the jack. always lossen them 1st while on the ground than lift the car...good luck
Yeah. Your suppose to loosen the lug nut when the tire is touching the ground. Once loosen you then jack up the car. Get a extendable Gorilla Wrench to ease removal and also get a torque wrench to torque the lug nut proper in the future. The longer handle gives you more leverage. The stock wrench is useless on over tighten lug nuts.
http://www.tirerack.com/accessories/tools/tools_all.jsp
Chu...
Chu...
Thanks Guys!
I will go to AutoZone in the morning and get a torque wrench. I'll WD40 the lugs first and let it sit for a couple hours. The only wreng I have right now is the L Wrench for the lugs that came with the car.
Thanks again, I'll keep you posted.
Adrian - I'll post the photos as soon the rims are on and the car is lowered (Monday afternoon).
You can also do this if you don't want to purchase a Gorilla Wrench. Stepping on the OEM wrench is dangerous. Never need to with the Gorilla Wrench.
http://lexusmodz.netfirms.com/GS_DIY/wrench/index.html
Chu..
Chu..
Chu..
Chu..
The One
Originally posted by Darius2004
Thanks! Looks Like I'll be going to Home Depot first! Cool, HD is right down the street and AutoZone is 15 miles away.
I liked it so much I bought a slightly bigger one for my normal wrenches to get better torque.
As for a torque wrench, it is a must if you are going to do DIY. With after market rims, you don't want to over or under torque. With it you can tighten all the nuts on all the wheels at the same setting. In case you are wondering and if the wheel manufacturer did not specify, I usually set it to 76 ft-lbs.
The One
Originally posted by aliga
why is it dangerous?
1. you'll probably fall and, depending on your environment, can hurt yourself or do damage to the things around you,
2. catch the lug in a weird way with the wrench and potentially strip the nut making it more difficult to get off.
