View Poll Results: How much air do you guys put in your OEM 17" wheels/tires?
Below 32 psi (please specify your reason)
0.67%
32 psi (what Lexus recommends)
49
32.67%
33 - 34 psi (please specify your reason)
26
17.33%
35 - 36 psi (please specify your reason)
43
28.67%
37 - 38 psi (please specify your reason)
6.00%
39 - 40 psi (please specify your reason)
15
10.00%
Over 40psi (please specify your reason)
4.67%
Voters: 150. You may not vote on this poll
All GS owners with OEM 17s please report in
Old 09-17-04, 09:04 PM
e-man
e-man's Avatar
Cadd -- I run my 17s at 30 (cold). The probably heat up to 32 when hot. I know it's a little low, but I prefer the cushy ride. I can personally attest to the camber problem. My car had been pulling relatively hard to the right. The guys at Lexus noticed some uneven wear on the inside of the front left tire. I rotated the tires front to back and it corrected the problem. However, I expect that I'll have to deal with the same problem over time with the tires that are on the front now. Hope this helps.
e-man
P.S.: When did you finally pick up the 17s? I know you had been looking for quite some time. Did you go with chrome or non?
Old 09-18-04, 07:00 AM
Cadd
Cadd's Avatar
Hey e-man,
I picked up the chrome set less than a month ago from a CL member. However, I ran into minor issues. One tire had a nail which was leaking very very slowly and another wheel had a valve problem that kept on leaking.
I finally got them fixed and mounted them about 2 weeks ago.
Old 09-18-04, 12:34 PM
e-man
e-man's Avatar
That's too bad you had those issues. Glad to hear you got it taken care of. The nail is no big deal, but the leaking issue is a little more substantive. I assume the person you bought them from didn't know about the problems, right?
How do you like the ride of the 17s?
Old 09-18-04, 02:21 PM
Cadd
Cadd's Avatar
I don't think the seller knew about these issues. He is very honest. If he knew about them, he would have told me. It could have been dangerous.
I mounted them on and rode on them for a few hours. When I got in again to drive home, I realized that it felt funny. I came out and checked the pressure. It dropped to 25psi. I decided to check all 4 tires. Everything was good execpt for the last one. After I inserted the tire tester, the valve started leaking like there's no tomorrow. Luckily, I had my 16" wheels in the trunk and changed it on the side road. I also had a portable 12V air compressor so I pumped up the wheel with the nail.
Luckily, I wasn't on the freeway going somewhere.
I like the 17" ride. It's definitely more stiffer and sportier than the 16s. The car feels more responsive now. However, there are times after a tiring day at work, that I would prefer a nice cushy ride home (on the broken streets of Brooklyn.....and that's the only time I miss the 16s).
Also, the road noise is a bit louder with the 17s.
So, now I have 2 sets of 16s sitting in my basement. I have to get rid of a set. Taking up too much space.
Old 09-19-04, 05:16 PM
Lexy GS430
Lexy GS430's Avatar
i never buy anything that just came out new especially the new GS cause i think its all new design ground up.Lexus or not 3 to 4 years is enough time for them to work out all design problems.Don't take anything less then the best.Enjoy what you got which is nothing more then the best,and hook it up pimp statues.
Old 09-19-04, 05:19 PM
Lexy GS430
Lexy GS430's Avatar
oops sorry wrong post.
Old 08-30-05, 09:14 AM
LXBOY
LXBOY's Avatar
Mine are stock 17" chrome rims and the door jam recommends 33psi, I believe. I had 35 psi but after reading the instruction I brought them down to 33psi cold pressure.
Old 08-30-05, 09:37 AM
upstateGS4
upstateGS4's Avatar
Originally Posted by NT2SHBBY
guys he said 17's....the two that replied, if you read their sigs they run 19 & 20's.
I can understand 19's and 20's goin at 40psi, you need to.
I run my L-tuned 17's at between 32-34
hey man i just got a set of the oem 17 inch 5 spoke gs wheels and am buying the l tuned suspension...would you happen to have a pic you could throw me of your setup since i think its the same? thanks in advance
mike
Old 08-30-05, 10:10 AM
DASHOCKER
DASHOCKER's Avatar
I put 33 psi according to the manual. Ride comfort and fuel efficiency is important to me
Old 08-30-05, 12:26 PM
chuckb
chuckb's Avatar
mike
I don't think he will reply since he's and the thread's a yr old.
N2shbby had bilstein/eibach S/S and stock 16s and 17inch turismos
search cinfulxgs4, he has/had 17s and Ltune suspension.
Old 08-30-05, 01:41 PM
upstateGS4
upstateGS4's Avatar
will do. thanks.
Old 08-30-05, 02:47 PM
Indio
Indio's Avatar
Here you go.
Old 08-30-05, 05:54 PM
upstateGS4
upstateGS4's Avatar
Originally Posted by Indio
Here you go.
lol i just found that exact car for sale on ebay and i said to myself, SCORE i found pics, haha, but thanks bro. i just bought the shocks and springs from sewell. have a good night guys.
Old 08-30-05, 08:43 PM
GSXLEX
GSXLEX's Avatar
I run 35.I figure when warm they rise to 38-39..Jerz has ****e roads so it soaks up bumps but still feels planted..
Old 09-01-05, 03:58 PM
TAMR_GUS98
TAMR_GUS98's Avatar
Default Psi?
Running S03s in 245/45ZR17 at 36 psi. Seem to get the best tire wear and best gas mileage at this setting.(max is 44 psi, I think)
Will
Quick Reply: All GS owners with OEM 17s please report in
