View Poll Results: What Octane do you put in your '98 - '05 GS4?
86 or below (available in Ohio, Michigan, Indiana, West Virginia, Kentucky, etc.)
0%
87
4.41%
89
5.88%
91 (does 91 exist? I'm not 100% certain.....)
45
33.09%
93
71
52.21%
94 (Sunoco)
2.21%
95 or above
2.21%
Voters: 136. You may not vote on this poll
What Octane do you use for your 1998 - 2005 GS400?
Old 09-30-04, 09:04 PM
  #31
mikeyboy
mikeyboy's Avatar
I've got place here that sells 114 octane for like 5.07 a gallon. I personally have never put that in my car, lol, but if anyone is willing to try i will direct you.
Old 04-28-06, 11:19 PM
  #32
SRK
SRK's Avatar
I voted 91, but that's because I use 92 and it wasn't listed.
Octane requirement for the engine (not what the driver "thinks" is best for whatever reason) is dictated by throttle opening. If you don't use full throttle, and just drive gently all the time, the engine will be perfectly happy on 86, and not knock or retard timing at all. If you use full throttle, then the octane requirement goes up and 91 would be needed to maintain ignition timing.
All octanes are equally well refined and blended, there is no difference in quality other than the anti-knock value.
Hasn't this topic been beat to a pulp before?
Old 04-28-06, 11:38 PM
  #33
crilla
crilla's Avatar
91 is the higest in alaska
Old 04-28-06, 11:58 PM
  #34
LEXUS_KID
LEXUS_KID's Avatar
Old 04-29-06, 05:16 AM
  #35
jonathancl
jonathancl's Avatar
The desire for higher octane fuels is nothing more than successful, misleading advertising by producers.
Higher octane than the car is tuned for won't make your car do anything better and is thus wasted money; lower causes the car to retard performance.
If the car wants 91, that's what you should give it.
Old 04-29-06, 08:46 PM
  #36
TAMR_GUS98
TAMR_GUS98's Avatar
Question Slow or Fast Burning?
O.K. Let me ask you guys this. Is higher octane fuels slower or faster burning?
Old 04-29-06, 08:57 PM
  #37
Lexbox
Lexbox's Avatar
Down here in Alabama we only have 87 89 and 93 so I use 93 for my baby. I dont know about burning slower but I think the higher the octane the harder it is to detonate.
Old 04-30-06, 05:54 AM
  #38
Hardaway33
Hardaway33's Avatar
I used 87 for about 2 months and the engine would idle badly and even cut off some times! Since I changed to 92 I have had no problem, rough idle problems cured!!
Old 04-30-06, 06:04 AM
  #39
Rockville
Rockville's Avatar
Default Higher Octane means a higher burn temperature..
so that is slower. Preignition is when the compression and friction prematurely light the lower octane fuel and on some engines can do damage. The fuel efficiency will be worse on an engine designed for Premium octane if you use Regular so the savings may be illusory. If you have greater than 10:1 compression the fuel choice should be 91 or higher Octane. This is explained on the last page of the owner's manual. If you are running out of gas and Premium is unavailable put the lower octane in enough to get to a source of Premium. Do not floor it as that will cause predetonation. Conversely, if you own a car that is designed for regular unleaded then putting high octane fuel in it would be a mistake also.
Rock
Old 04-30-06, 04:01 PM
  #40
Shawnmack
Shawnmack's Avatar
I use the gold at the BP station they used to have that clear gas with the little ball that moves when you pump the fuel.
Old 04-30-06, 10:26 PM
  #41
TAMR_GUS98
TAMR_GUS98's Avatar
Thumbs up Slow Burning.
Rock
Very good Rock. The fuel that burns slower is less succeptable to preignition and detonation.
Old 05-01-06, 01:53 AM
  #42
aloha08isf
aloha08isf's Avatar
i use premium gas every single time...especially in a lexus...i would NOT put anything other than preminum...i believe its 92 octane here in hawaii...
Old 05-01-06, 10:48 AM
  #43
Titanium
Titanium's Avatar
93 here only.
Old 05-02-06, 03:49 AM
  #44
joeydingo
joeydingo's Avatar
93 Texaco or Sunoco
Old 05-02-06, 04:44 PM
  #45
brit_lex
brit_lex's Avatar
regular unleaded is 95 here in the UK. they recently brought out 99 octane super unleaded, which is supposed to benefit turbo engines. and also we have 102 octane that just got released. I typically fill up my GS with 99..
Quick Reply: What Octane do you use for your 1998 - 2005 GS400?
