GS300: 30k Service Costs - Sticker Shock
#32
I had the 30Kdone on my '01 and just about fell over from the sticker of $360. My '03 is due now for the 30K. I purchased the oil (syn), filter, cabin filter, diff fluid (syn), wiper blades, and antifreeze for about $ 125 and I figure I can change it all in about 4 hours if I take my time. I will have to pay the Lexus dealer to flush the brake fluid (about $100). The tranny fluid is syn already and per the master Lex mechanic around here is good for 60K miles or more. When it came time for my '01 to get the 60K the cost was over $800.
#33
Originally posted by TAMR_GUS98
$320 something for a 60k is lower than dirt cheap. What did they do for that price?
If the particular dealer you deal with has the AAA discount, they usually have a sign that advertizes it in the service drive. You can also call and ask them by phone or in person. Btw, even with the AAA discount, you wouldn't pay anywhere $320 for a properly done 60k
Will
Will
Perform 60,000 Mile Maintenance Service.
REPL OIL/FLTR, ROTATE TIRES. REPL: AIR FLTR, COOLNT, BRK FLD, TRANS&DIFF OILS. INSP:A/C FILTER, BODY/CHASSIS, NUTS/BOLTS, FUEL LNS/CNNCTS, FUEL TANK VAPOR/BAND/CAP GSKT, VENT SYS HOSES, EXHST PIPES/MNTS, BRK LINING/LINES/HOSES, STEER LINKAGE, RACK&PIN ASSY FOR LEAKS, BALL JNTS, DST CVRS DRVSHFT BOOTS, RETORQUE FLANG BOLTS. ROAD TEST. BATTERY TESTED
PART NUMBER------------------DESCRIPTION---------------------------------------QTY
LEX002721LLACLX01---------ANTIFREEZE LEXUS-------------------------------1
LEX00279000T4-----------------ATF T-IV CASE---------------------------------------2
LEX0892202011-----------------FILTER S/A, OIL--------------------------------------1
LEX1780146090-----------------ELEMENT S\A, OIL ----------------------------------1
LEX3517850010-----------------GASKET, TRANSMISSION-------------------------1
LEX9043012031-----------------GASKET ----------------------------------------------- 1
01000010WSFLD----------------WINDSHIELD SOLVENT---------------------------1
0103910102212------------------BRAKE FLUID-----------------------------------------1
010KITMOC1-----------------------FUEL BATT--------------------------------------------1
01002871---------------------------A/M BATTERY CLEANER---------------------------1
01001061---------------------------A/M FUEL SYS/TREATME---------------------------1
010GEAROIL-----------------------GOG------------------------------------------------------1
0107192424812-------------------5/30 MOBIL 1------------------------------------------6
ADD ENGINE TREATMENT
01001211----------------------------A/M PREMIUM ENGINE T -----------------------------1
of course, there was a loaner car provided total with AAA discount: $329.13
So did they do what they are supposed to do for 60K??? Anyone???
P.S. A fellow CL member GlobalCLK also got his 60k service done at Longo for a little bit less than what I paid for.
#34
Originally posted by GSXOTIC
Well, you got me curious so I look at what they have done and here is the receipt:
Also, if you look in your owners manual under "Maintenance" you can find out what a 60k intails.
Will
Johnhw2
08-30-16 03:15 PM
jbm79
ES - 6th Gen (2013-2018)
41
07-29-14 08:07 PM
Gojirra99
07-21-06 12:09 PM
