Ran out of gas in my 2003 GS430 - Exact size of Gas tank
for some reason i think the gs400 gets better gas mileage than the 300, if i would have known i would have gotten a 400, oh well, i was thinking cause its a big 6 cylinder that has to work harder than a 8 cylinder motor wasting more gas, could be wrong, but my 300 gets 250 to the full tank while everybody else talks about getting 400, this sucks
i have gs4 and is3, both eat gas about the same
Good grief...you guys who get 400+ miles to the tank, that is IMPRESSIVE!
I'm always at 1/4 tank right around 245 miles....and I drive (95% of the time) where my gears shift under 2000 RPM, so I'm no Speed Racer...
I need to move to the mountains...haha
though now i always get gas as soon as it hits the 1/4 mark @_@
Originally posted by rominl
actually if i just drive on the highway without traffic (and if i can refrain myself from gunning the car a few times here and there), putting 400 miles in a tank is definitely doable
My GS4 runs out not long after the low fuel light comes on.
I don't know if I have ever been able to put more than 17-18 gallons in ever. I thought I had read it was a 20-20.5 gallon tank. Maybe I read it wrong.
The GS has essentially 2 gas tanks, a left and right. It has a siphon jet so it can pull from the other tank (the one the pump isn't in), I think mine doesn't suck well off the other side one (right I think). I need to get the back seat out and pull the covers to see what is up on mine.
Ive probably run out 5-6 times now. I can't push the car when that light comes on AT ALL. If it comes on, I stop at the first station I find.
My GS400 is the same. A few times now I have run out of gas within about 10-15 miles of the low fuel light coming on. Once I was out of gas before the light even came on and the gauge was still showing about 1/8 tank left. I had to get my tank rebuilt about a year ago because it was leaking. I think the siphoning hasn't worked right ever since. I am also think maybe my fuel pump is getting weak.
is this siphon jet in the 430 also or just the 400? I know the 400s tend to have issues with the fuel filters and fuel pumps which I THOUGHT they changed something in the 430 so it doesnt happen anymore?
Both, should be the identical part.
My GS has nearly 240k miles and I have no evidence the fuel filters or pump have ever been changed. The filter will probably get changed this summer just because....
I'll ask my lexus guru.
