Problem programming new master key
Old 10-08-04, 08:46 PM
Ex540guy
Ex540guy's Avatar
Default Problem programming new master key
Bought a new master key from Darrel at Sewell Lexus. Got it programmed to start the car, but can't get it programmed to open the doors. I followed these instructions, which I believe came from a post Romini found:
Okay, here they are. I'm also including some additional trivial notes that may or may not make a difference.
I was given two sets of steps to run. I'm not entirely certain that both sets have to be performed, but it worked for me (after a couple of false tries).
FOR CARS WHERE YOU WANT TO CREATE A SPARE KEY:
Before starting, press and release the Brake and Accelerator pedals at the same time.
1. Place an already programmed Master key in the keyway (Do not turn on)
2. Press the Gas pedal 5 times.
3. Press the Brake pedal 6 times.
4. Pull out the key.
5. Insert the new key but DO NOT turn it on.
6. Press the Gas pedal just 1 time and wait until the security light stops blinking (about 1 minute).
7. Remove the key and press the Brake pdeal 1 time. The cycle is now closed.
The programming mode will end after 10 more seconds.
REGISTRATION OF RECOGNITION CODE
1. Open driver door, keep it open and in the unlocked position (all other doors should be closed)
2. Put original key in ignition and pull out
3. Lock and Unlock the doors 5 times (complete each lock/unlock cycle within 1 second and
entire process in 40 seconds or less)
4. Close the door and open the door
5. Lock and Unlock the doors another 5 times (complete each lock/unlock cycle within 1 second and
6. Put the new Master Key in the ignition, turn it to "on" and then off (with 1 second) and remove from the ignition.
7. Press and hold transmitter LOCK and UNLOCK buttons simultaneously for at least 1.5 seconds,
and then within 3 seconds; press any transmitter button for at least one second.
8. If within 3 seconds, door locks cycle one time, new transmitter code was accepted. If door locks
cycle 2 times, new transmitter code was not accepted. If code was not accepted retry step 8 again.
Tried four times, but no luck. The door locks still cycle 2 times, indicating code wasn't accepted, and the doors don't open. Any suggestions?
Old 10-08-04, 09:05 PM
chuckb
chuckb's Avatar
man, thats a wierd, complicated ritual!
Old 10-09-04, 03:13 PM
tofu_house
tofu_house's Avatar
Default whoa..
those steps remind me of the ps2 codes in GTA... press X triangle x square x circle x x saure triangle r1 r2 l1 l2... wow confusing...
Old 10-10-04, 07:21 PM
VVT-i
VVT-i's Avatar
Default Re: Problem programming new master key
Originally posted by Ex540guy
[COLOR=blue]3. Press the Brake pedal 6 times.
2Tried four times, but no luck. The door locks still cycle 2 times, indicating code wasn't accepted, and the doors don't open. Any suggestions?
1. Driver door is opened and another 3 three doors are closed and IN LOCKED POSITION.
When you do the Lock and Unlock make sure you are using the manual operation with the lock buttom by the door handle( not from the master switch).
After you do the lock and unlock for 5 times and close and open the driver door.
Then do the lock and unlock for another 5 times.
Then, insert the key, turn it on and off, and remove the key from ignition. You will hear the door lock cycle once.
Then, hold the lock and unlock buttom on the new key for a few second and then press either lock or unlock buttom.
Now, you can close and open the door to end the remote entry.
Old 10-10-04, 08:56 PM
Ex540guy
Ex540guy's Avatar
Thanks, VVT-i!
The "key" (get it?) to the whole procedure is to use the manual lock (not the power lock) and to make sure the other three doors are locked. To summarize:
1. Open driver's door, keep it open and in the unlocked position. All other doors should be closed and locked.
2. Put original master key in ignition and pull out. This is the only step which requires the original key.
3. Lock and Unlock the driver's door 5 times, using the manual lock, NOT the power lock. Complete each lock/unlock cycle within 1 second and the entire process in 40 seconds or less.
5. Lock and unlock the driver's door another 5 times. Complete each lock/unlock cycle within 1 second and entire process in 40 seconds or less.
6. Put the new master key in the ignition, turn it to "on" and then "off" (with 1 second) and remove from the ignition
and then within 3 seconds, press Lock or Unlock for at least 1 second
8. If within 3 seconds, door locks cycle one time, new transmitter code was accepted. If door locks cycle 2 times, new transmitter code was not accepted. If code was not accepted, retry step 7.
Old 10-10-04, 09:50 PM
ILOVEGIRLS
ILOVEGIRLS's Avatar
so did it work?
Old 10-11-04, 01:53 AM
rominl
exclusive matchup
rominl's Avatar
damn this is cool, guess it's helpful when i do my master key program soon enough
Old 10-27-04, 07:35 PM
PHML
Master Thread Closer!!
PHML's Avatar
What about the remote button to pop the trunk?
How is that programmed?
Pete
Old 10-27-04, 08:30 PM
Ex540guy
Ex540guy's Avatar
When I programmed the key as per the instructions I posted on 10/11, all three buttons on the key were programmed.
Pete
Old 10-27-04, 08:32 PM
rominl
exclusive matchup
rominl's Avatar
Pete
i would think as long as you program the doors the trunk will work automatically?
Old 10-27-04, 10:39 PM
ntran18
ntran18's Avatar
Programming the power door locks includes the trunk. What got me when I did this was I pressed unlock first instead of lock. But I was able to do this using the power door locks on switch on the door. Whatever works...
Old 10-28-04, 06:17 AM
clarky86
clarky86's Avatar
Did the key come to you cut? How much $$ was it? I may be doing the same thing soon. Thanks
Old 10-28-04, 07:13 AM
Ex540guy
Ex540guy's Avatar
Key was cut. $165.
Old 02-22-05, 02:41 PM
edfrsd
edfrsd's Avatar
Default Which one should I do?
I just bought a cut key from Sewell and not sure which programming to do.
Am I supposed to 'Create a spare key' or do the 'Registration of recognition' ?
When programming a 'spare key', will the unlock, lock and trunk buttons work?
Old 02-22-05, 03:01 PM
Ex540guy
Ex540guy's Avatar
You have to do both. Follow the steps for "Create a Spare Key" from post #1 above, but use the instructions for "Registration of Recognition Code" from #5. If you do it right, all button on the new key will work.
Quick Reply: Problem programming new master key
