HELP! Rod Millen Sway Bars Squeaking!
I installed my Rod Millen Sway bars (intrax) not too long ago and after a while they started squeaking when i went over bumps or accelerated... I tried bringing it to the dealer and had them relubricated 3 times already but the sound keeps on coming back.. I remember that someone posted a solution to this by replacing the bushings, what size do i need and where can i get them from? This is for a GS400 btw..
-Chris Y.
-Chris Y.
....BANNED! :-)
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
BBD - You don't have to worry . A strut bar is different from a sway bar . A strut bar goes on top of the engine and sway bars goes on the front and rear bottom of the car.
I also have the RMM strut bar and love it .
CJGS4 - I wish i could help you . I remember something about switching the rear bushing switched from right to left to make it fit right . My memory is kinda fuzzy right now so sorry i couldn't really help you.
Chris, I have anti-sway bars on a non-Lexus car that used to squeak until I got greasable poly bushings from Energy Suspension. They have built in zerk fittings, all it takes is a shot from a grease gun once a month--takes one minute!
-Chris Y.
-Chris Y.
I have the same unit. The rear bushings have to be switched from left to right. The installer should have grease the units and there is a grease joint for regreasing.
My problem with the intrax is they broke my rear OEM links that attach to the swaybars. Why did this occur? If the OEM components cannot handle the stress Intrax/RMM should have not sold the swaybars with such a range of adjustment.
If RMM reads this I am one angry customer. I've left you guys messages and no one has replied to them. Please get in contact with me to rectify this. You must support your customers otherwise your reputation will keep sinking......Call me as I don't like driving with no rear swaybars....
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
Guys - As ya'll know, I'm not the autocrosser in this Forum but I don't think the swapping of the end links would SUDDENLY cause squeaking. Those needed to be swapped to allow proper installation & correct geometry for the rear bar. The ones I have from RMM/Intrax came with zerk fittings to allow greasing & I do so every time I change oil/filter as part of my routine maintenance. So far I have no squeaks but also installed mine with some lubricant ( actually, Copper Shield ) & they weren't squeaking before I greased them the first time after installation.
Mike - I'm no suspension expert but i'm with U. Why should the end links need to be swapped from side to side in the first place when the factory Lexus bar was already in place? I can see using larger hardware to accomodate the thicker bar but swapping sides??
My old Guldstrand bars on the 'Vette were direct swaps, as were my bars on my RX-7 so why's the RMM kit different? To anyone who has the TRD bars - was this process necessary? How about it, Steve?? BTW - hope you're feeling better!!
Jacob - I'm not doubting you at all but U have the first set of RMM/Intrax bars that didn't need the end links swapped. When didja get yours? I got one of the first sets RMM sold because I had a deposit down on them 4 months before they were FINALLY released!! Maybe RMM worked out that problem at a later date?? Mine R purple & have the Intrax label on them. Even my instructions had a leaflet that said to swap the links but I called my salesman anyway & he verified it. Guess you're living right, my friend!!
RA - FWIW, I like the RMM bars, even with the swap necessary. From pics I've seen, the TRD's are much sturdier so if U push your GS hard into the curves, might want to get those from Steve. For me ( as I said before ), I'm a straightline guy so the RMM's are OK for me.
