STB torque
Puck - I am sure they will fit on top of the Teins . If memory is correct. A member with the Tein setup will help you further.
As for the TRD stb its 35 nm . There was a thread in the suspension section that i had asked the same question. But its got sucked up by a black hole
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Yes they do fit as I am running Teins HA's with the TRD strutbar. There is a little hole in the STB for using your Tein tool to allow for adjusting the damping on the coil-overs. Saves a lot of time.
Hope that helps...
Hope that helps...
Originally posted by Puckhead
Thanks mkilty.
Have you guys actually changed settings on your Teins?
Is it very difficult?
Thanks mkilty.
Even changing the height of your shocks is easy as the Tein's have two wrenches for that purpose.
Have fun....
Hameed
Suspension and Brakes
11-21-03 09:26 AM
