New lexus owner and windshield question
Hey all - I just bought my first Lexus (on Ebay :-)) - a 2001 GS430 and I'm stoked to have found this forum - it's awesome - tons of info!! I don't know much about these cars so I'll be having a ton of questions - and here goes my first.
My car has a lot of wind noise coming from the windshield area when I get above 45 mph. I took it to the Lexus dealership and they said that the windshield isn't oem and therefore has a wind/air leak at speed which is causing the noise. They said that I'll have problems with anything other than Lexus glass and I need a new windshield to the tune of $1100. Are they just trying to get business and should I try getting a new windshield from a local autoglass shop for around $225? I can't imagine that a well installed windshield couldn't fix the problem even if it's not oem glass - but if it's really the case better to cough up the $1100 now I guess.
Thanks for any suggestions.
Just a thought, but are you sure it's coming from the windshield? The reason I ask is because I had a similar problem (so I thought), but it turned out to be the fact that the undercarriage plugs were missing from my car. In short, if the undercarriage plugs fall out, at highway speeds, air rushes up through the holes, up through the a-pillars, and it seems as if you have a wind noise problem coming from the front corner of the windshield where it meets the window. Check under your car to see if the plugs are there. I believe there are a total of 6 -- 2 in the front and 4 in the back. You will want to focus on the 2 front ones. They are positioned just behind the front wheels, about one foot in from the side of the car. You can't miss them. They're about $2 to replace, which is a heck of a lot easier to swallow than several hundred or more. Let us know how it turns out.
e-man
e-man
Wow - thanks for all the reply's - I really appreciate it. So first thing I'll check is the undercarriage plugs as e-man suggests , if the plugs are there - I'll try going for a replacement windshield from local autoglass shop. Hopefully one of those will fix it - this is coming out of my own pocket so oem glass will be a last resort I guess.
One more interesting thing about windshields: even replacement windshields cost godawful, but when you mention your insurance, all of a sudden the price generally will become whatever insurance will pay and you are only out the deductible on your comprehensive (which is, I think, where Neo was going with his post). At least, so has been my experience in times past..........
And I agree that there should be no problem with any local reputable glass company, regardless.
I had a chip and had it replaced for free via insurance. In FL there is no deduct for windshield. I also insisted on oem and an oem molding kit. The dealer told me who does their winshields and sent me to them for install
OEM Windsheild
Wow, $1100. I heard from a dealer that some of the Lexus windshields are impregnated with rain repelling substance. I was wandering maybe thats why its so expensive. Have any of you heard of this before?
Re: OEM Windsheild
Re: Re: OEM Windsheild
Originally posted by joshoowa
well i dont know about others but i notice that my windshield and rear windshield beads water way better than any of my friends cars. i dont use any chemcials on my windows either.
I have also seen aftermarket winshield that look wavy from side angles.
e-man
e-man
I got mine at the Lexus dealer. They had to order it from the warehouse, and it took about 3 days to come in. Just go back to the parts department and ask. They should be able to figure out the part number by by looking at a parts diagram. By the way, if I were you, I would get at least 2 and replace the one that you still have up front (I assume the missing one was up front). The plugs tend to dry out over time, especially in colder climates, and the one that's still there will probably fall out eventually. Good luck and let us know if it works.
e-man
e-man
