DRAFT GS Forced Induction Registry
Old 02-14-07, 05:35 AM
  #91
adamgamz
adamgamz's Avatar
Same here, 01 GS300 NA-T T60-1.
Old 02-14-07, 01:42 PM
  #92
macd7919
macd7919's Avatar
I could be added as well.
Old 03-03-07, 05:26 PM
  #93
GSoup
GSoup's Avatar
2nd gen GS300 / NA-T / T61
I'll post up some numbers soon when i get al the bugs out and get it finally tuned to perfection
Old 03-06-07, 01:17 PM
  #94
MyAristo
MyAristo's Avatar
Default MyAristo 2JZ-GTE VVTI - 383 RWHP
So here goes...
I will like to give a big thanks to Punch10. Without you I couldn’t have done this. Second Farley @ GR Racing (He is a supra God).
This project was done in 3 weeks as promised by Farley & his partner Chris. Everything works. Yes I mean everything. No check engine light, VSC works, Cold AC etc…Specs below.
If you have any questions email me at MyAristo@Gmail.com or MyAristo@MyAristo.com
• 17.5 PSI ON 93 OCTANE.
• APEXI S-AFC2 Fuel Controller
• APEXI AFC - Custom Setting Tuned by GR Racing
• Custom Built ATF Accumulator And Valve Body Kit
• B&M Racing Oil Cooler
• Turbo Smart E-boost 40 PSI Controller
• HKS Turbo Timer
• Custom Built 3in Into Two 2 1/2in Mandrel Bent By Florida Performance
• Turbo Piping Is Stock And Feeds Into Custom 3in Intercooler Piping
• Walbro High Pressure 255 Liter Custom Adapted To Return less Fuel system
• Intercooler Core Custom Piping 3in Mandrel Bent And Polished By GR Racing
• 3in Custom Down Pipe
• Stock Turbo Inlet Pipes
• Stock Fuel Pressure Regulator,
• Stock Factory thermostat
• Stock Radiator Dual Fans
Thanks
Old 04-03-07, 01:10 PM
  #95
GSoup
GSoup's Avatar
Here's some pictures of it ... work in progress...
Old 04-06-07, 11:33 PM
  #96
samster
samster's Avatar
lol Gsoup you do ur moddin outside of the PJs?
what exhaust mani are you running?
Old 05-04-07, 09:26 AM
  #97
99SC42
99SC42's Avatar
you guys are just awesome,keep up with the good work .Thanks DaveGS for starting this theard that's a lot of info for me to set mine up.
Old 04-09-08, 05:17 AM
  #98
VEGAS DRE
VEGAS DRE's Avatar
Default Maf ???
WHAT SIZE INJECTORS IS ON YOUR SETUP? Wheres Your Maf Sensor ? Did You Eleminate It ? Ifso What Did You Use To Bypass It ? My Buddy Just Got His Is 300 Boosted And Theyre Having Tuning Issues Caused By The Maf Sensor On 14.7 Lbs Of Boost With A Turbonetics 60-1 Hi-fi. With A Walbro Fp,550cc Rc Inj.,apexi Safc Neo !
Old 04-09-08, 06:08 AM
  #99
adamgamz
adamgamz's Avatar
I ran a MAP ecu for awhile to eliminate the MAF meter, the car still never ran right. Unfortunatly these cars (IS and GS) require stand alone engine management to do it right, here are a couple of pics of my project, its getting very close to the end.
Old 06-01-08, 01:34 AM
  #100
Lettuce
Lettuce's Avatar
Old 07-10-08, 08:00 AM
  #101
zebt66
zebt66's Avatar
Missed my GS 300...
1998 GS300
Mods:
-2JZ-GTE VVT-i Aristo swap with 4-speed tranny and ECU
-Aristo rear end with Limited Slip Differential
-HKS F-Con Pro V Engine Management (fully tuned)
-Precision GT40-67 Turbo with Garrett parts
-Custom heat coated race manifold
-Tial Wastegate
-Tial Blow of Valve
-Innovate Wideband
-AEM Boost Controller/Boost Gauge
-Precision 750hp Intercooler
-Custom 3" piping with everything polished
-Boostlogic Turbo Blanket
-Precision 850cc Injectors
-Ross Machine Racing -10 Fuel Rail (Dual Feed)
-HKS DLI Ignition
-Custom Power Steering Reservoir
-Steel Braided Fuel Lines and Anodized Fittings
-Twin Walbro Fuel Pumps
-Aeromotive Fuel Pressure Regulator
-Greddy 10-60 OIL
-HKS Dual Hi-Power Exhaust
-Custom Intake with K&N Air Filter
-Rear Lights LED
-6000 HID
-Axis Milano 9.5 rear and 8.5 Front
-Tanabe lowering springs
-Cross drilled and slotted rotors with ceramic pads
-Full JL Audio Speaker Set up with two 10's in the trunk
-JL Audio Amplifier
Old 07-21-08, 01:27 PM
  #102
TheMadGS3
TheMadGS3's Avatar
Is this list even updated anymore? lol We need someone to make/keep updated alist!
Old 12-03-08, 11:51 AM
  #103
black_gs99
black_gs99's Avatar
Edit......
Old 12-03-08, 12:02 PM
  #104
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,260 Likes on 1,373 Posts
If somebody is REALLY good with Microsoft office stuff I can dig up the original source and hand it over for them to update the details. PM me if you want to volunteer!
Old 04-29-09, 03:09 PM
  #105
sam430
sam430's Avatar
Okay,
you guys are old school...
here...share it to the world.
http://spreadsheets.google.com/ccc?k...LipgAnv295X0rg
Make your own edit. This Spreadsheet is open to everyone to view. To make changes, signin on the top right corner. Anyone with a gmail account can make edits.
Quick Reply: DRAFT GS Forced Induction Registry
