Question for those w/ LMW Sense O Shock Alarm
Question for those w/ LuxLink Alarm
I recently installed the Sense-O-Shock system from Luxury Motor Works. I tried testing the alarm by shaking the car, but alarm doesn't go off. I suppose this has something to do w/ the sensitivity setting? I want to make sure that the alarm is suppose to go off if I do his before I remove the glove box to get to the setting.
Another thing is I rolled down the window and turned the alarm on. If I reach in, open the lock and open the door, isn't the alarm suppose to go off?
Any help is appreciated.
Edit: I think this might need to get moved to the Security section.
exclusive matchup
umm.... something must be wrong man.
yeah you can try to adjust the sensitivity. what they did when installing was not to put back the glove box door assembly first, and adjust the sensitivity until it's good. to the point that if someone hit the car the alarm will go off. then they put eveytihng back for final testing
now if you open the windows, lock the car, reach in and unlock the door, the alarm should go off even with the stock setup. that feature shouldn't have anything to do with the luxlink setup at all?
now i am just wondering will the Sence-O-shock fix this problem???
exclusive matchup
Originally posted by GS400kid
last week i was messing with my friend, i locked him inside, he just simply unlock from inside, alarm didnt went off at all. we were all surprise it didnt go off...
Someone should do a step by step writeup with pictures on how to install the sense o shock alarm. A lot of people got into the GB in the vendor section and I'm sure there's a good portion that would greatly benefit. Any takers??
exclusive matchup
Master Thread Closer!!
Well..pics always help clarify alot of things put in words.
LMW installs these things quite often....so they just need to grab a digi cam and take some pics.....not too hard to do....and email or send pdf file to peeps who bought it....since posting up here may jeopardize their proprietary system.
Alarm won't go off.
Just wondering if you guys were waiting for the alarm to set befor unlocking from inside. I think you have to wait 30 seconds after you lock the doors. You can tell if its set when the LED starts to blink/flash. Just my .02 cents. Hope it helps.
Will
Re: Question for those w/ LuxLink Alarm
Did you somehow disconnect the OEM alarm while you were installing the LMV alarm?
