Range of Keyless Entry??
#63
Originally Posted by rominl
yeah i agree, if they are the same, then there is no reason to change it to newer yrs. something must be different. i am still thinking about taking apart the c pillar, locate the antenna and extend it. any down side?
#67
All you wimps...
I extended the antenna on the receiver. Now max distance I am getting ~80ft without the chin and ~140ft with the chin. Definitely I can activate the doors further away now, YMMV. Haven't replaced the batteries yet. Might be able to go a little further.
Basically, what I did was connect the antenna to the ground. Making the entire frame the antenna. I will post a write up once I sit down to write with the pics.
My observations: Seems the receiver is the weak link since IS & GS use the same keys and the IS gets better range. Possible fix(?) switch the GS receiver with the IS receiver. Though prolly a pricey fix. The receiver is listed @ $533 for the GS. Would also be good if we can boost the signal of the key.
#68
Originally Posted by ntran18
All you wimps...
#70
I replace battery and still nothing, 98 GS. would a new key from ebay be of any worth? do they transmitters in keys go bad? I am one foot away sometimes, and nada.
and if I have to spend money, might as well go for a remote starter?
#71
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
All you wimps...
#72
Awesome man!!
Can you please do a write up??? PLEASE PLEASE PLEASE PLEASE!!
All you wimps...
