Finally got around to taking pics of the FINAL product
#70
LEXFORLIFE here is a pic of the bootom part of hood.. let me know if you need some more..if you look close on the right side you can see the hood prop that is built into the veilside hood but i dont use it.. i painted it a 2 tone paint.. with blakc an cinnabr.. also you can see the meshing isnt put down very good irhgt now.. im gettin some black epoxy put on it with a different color mesh (black kind). let me know fi you need anyting else.
![](https://www.clublexus.com/gallery/data/500/15917MOST_RECENT_032-med.jpg)
#71
Your car looks incredible! Just curious, did you buy that off a member of cardomain.com and repaint it and upgrade? Anyway, it looks amazing man! Congradulations.
John
John
#74
John
John
lexforlife.. .. the prop used in the veilside hood i dont use because it looked like it tweakerd the hood to a side.. so i built me a hood prop.. its stainless telel tube that i basiclly cut tto the length i want and then put rubber ends on it... IF you look at your... i put one end right behind the stock hood latch.. then i use the other end on the latch of the hood.. it is very sturdy this way..
