Door molding issue
Door molding issue
Does anyone have a problem with the molding on the bottom of the front doors? ON both the drivers and passenger sides the molding on the bottom is pulling away from the door.
I had someone jerry-rig fix it but they're both coming off and it looks horrible.
Does anyone have any idea how these can be fixed/new ones installed and how much they would cost?
Again, I was hoping to not go to the dealer but need a good body shop in N. NJ that can do this, assuming it can be done.
Thanks for the help!
I had this problem so I went to the dealer. The head tech came over, took one look at it, rapped it a few times with the back of a closed fist, and the problem was solved. I thought it was just a temporary fix, but it's been a few months and it looks great. I think there are some clips or double-sided tape behind those moldings, but I'm not completely sure. Maybe someone else who knows a little more about it can chime in.
e-man - maybe I didn't explain this correctly.
The piece that is haning is actuallly hanging from the bottom of the door. If you open the door it's the "rubber-ish" molding on the bottom of the door. It actually is now hanging and when the tried to use duct tape to hold it on, it only stayed on for a couple weeks.
So it's not the molding as much as it's the rubbery lip, I guess that's what you would call it. It seems like it seals the door on the bottom.
Sorry if I'm not describing it correctly.
There's nothing that it's attached to so I don't know how it could be replaced. I have a feeling it's a trip to the dealer on this one.
Thanks
Thanks
That's what I was thinking - clear silicone. I've never ever seen another car with this problem. It was fixed with the tape for a little while.
I feel like my car looks crappy because of it. There's gotta be some way to fix it tho, right?
Sorry about that. I misunderstood. I thought you were talking about the plastic piece that extends half way up the door. As for the rubbery piece, I would assume it's just tacked on with some sort of adhesive material. I bet you could call your Lexus dealership and they would tell you.
Yeah it appears that there's no where for it to adhere to. It's like when it rips off, it just hangs.
I'm going to try the dealer and see what they say.
Thanks!
Thanks!
I have the same problem w/ my 98 GS300. A friend gave me some super adhesive that has held for about 8 months. However, winter is upon us.
The dealer said it would be $270 to replace both doors. I'm stalling.
Thanks - that's good to know.
I haven't asked the dealer yet . I'm going to try some major adhesive glue or clear silicone.
I hate the way it makes the care look. I can't imagine how it actually started to come off - it's in such a weird spot.
Thanks
Thanks
Thanks
Thanks
Yeah that would make sense, huh, however I need to borrow a digital camera first.
NO, the actual piece that I'm talking about is on the very bottom of the door. When you open the door and at the very bottom there should be a piece of "molding" that runs across the bottom of the entire door. It acts like a seal between the door and the body of the car. I'm assuming that all GS' (all Lexus') have this. That's the piece that is starting to rip off the door.
Hopefully that explains it until I take a picture.
I'll try and do that when I get the car back from the mechanic and try so you guys can see what I mean.
I believe he's talking about the weather stripping at the bottom of the door to keep the seal closed on the bottom when the door shuts. I too have this problem. I put adhesive back on it to fix mine, drivers side is holding strong, but passenger side isn't . If i so much as touch it when i'm washing my car, it pulls back off. I have it. Not to mention that the piece that is hanging is turning yellow from oxidation. Gotta get it fixed. I am in DE, so let me know what a NJ dealer prices you at.
John
John
Will do.
I'm going to check out the dealer as well as try and fiix it on my own to start. I imagine that they would have to replace both doors and I'm wondering how they would do that.
I'll keep you informed and see if it's worth it.
Will advise....thanks!
