Repacing a Tail Light bulb (99 GS 300)
I need to replace my tail light bulb. Can anyone guide me? Where are the nuts to get into the tail light housing is in INSIDE the trunk or is it on the outside where the trunk if it were shut? Any help is appreciated...
MJC
MJC
there are tons of threads about this already, especially on how to take off the housing, if you do a search on "remove taillight" you should get a lot of answer
in short, there are 4 bolts/nuts holding the taillights. after you open up the trunk lid, on the side of the taillight, you see 2 black circular tab. pop them open, you see two 10mm bolt. use a hex wrench and get them off.
pull out the trunk lining right behind the taillight, you will see another two 10mm nuts. you need a deep socket to take them off. after that you can pull out the taillights easily
L-Sports
12-10-18 08:57 AM
