These wheels would look good on a GS?
Old 01-06-05, 06:40 AM
GammaLex
GammaLex's Avatar
Originally Posted by NT2SHBBY
LS 430 WHEELS DO NOT FIT THE GS!!!!!!!!!!!!!!!!!
I tried some 03 LS430 chromies on my car and all they did was shook and wobbled....
Lexus dealers tell me because of the caliper difference, thats why they don't fit
Chuck, don't waste your money.....buy my L-tuned instead
Well with a comment that you tried them its safe to say that you drove them. You even say it now that you drove. Im not going to argue with you if you want to can PM me.
GammaLex is offline
Old 01-06-05, 06:44 AM
Cadd
Cadd's Avatar
Those wheels do look nice. Does anyone know the specs? What size & what offset?
Cadd is offline
Old 01-06-05, 08:30 AM
Chigga
Chigga's Avatar
when a rim DOES fit on a car but got a problem like what you stated, its a good chance the inner bore of the wheel may be at a difference size, what about offset? are they similar or require spacers to probally ensure it can be tight down?
Chigga is offline
Old 01-06-05, 08:44 AM
GammaLex
GammaLex's Avatar
I checked the specs for some they are 18x7.5 with a 45mm offset and a 60.06 center bore.
GammaLex is offline
Old 01-06-05, 09:04 AM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
umm..... the ls430 and the gs shares the same lug pattern, and i would tend to believe they have the same bore (correct me if i am wrong). if that's the case, the wheels should fit (offset is another story of course)> all you need to use would be the lug nuts for the ls430. the lug nuts for the gs is special and might not fit on the ls430 wheels
rominl is offline
Old 01-06-05, 09:32 AM
CaMsGS3
CaMsGS3's Avatar
I think they wouldnt look that bad on the GS
Are these the same rims...........
CaMsGS3 is offline
Old 01-06-05, 09:38 AM
Neo
The One
Neo's Avatar
Well, from this, it should fit. There may have been a lug nut problem. Some wheels are universal, some needs lugs with enough (or less) depth to fit on the bolts correctly. For example, if it is not long enough for the rims, it will not seat all the way in.
Neo is offline
Old 01-06-05, 09:48 AM
Cadd
Cadd's Avatar
Those are knock-offs. They're not OEM Lexus.
Cadd is offline
Old 01-06-05, 09:55 AM
GS3Tek
Forum Moderator
GS3Tek's Avatar
RE: GS and LS compatibility:
I'm not sure if this will help but I have seen alot of 98-2000 GS 16's on the early 1st and 2nd gen LS.
I see those cars drive around them so I guess they have them on for a while already, not a test-fit.
Maybe someone can photoshop them to see how it looks?
GS3Tek is offline
Old 01-06-05, 09:57 AM
CaMsGS3
CaMsGS3's Avatar
i know that already, im trying to see these 05 LS rims up close
CaMsGS3 is offline
Old 01-06-05, 10:35 AM
Chigga
Chigga's Avatar
um, that seems to be the problem, the bore size on the hub is 60.1
Chigga is offline
Old 01-06-05, 10:56 AM
Neo
The One
Neo's Avatar
I believe the bore on the GS is also 60.06. It sometimes gets rounded to 60.1. Plus, .04mm is really not big enough to cause that much vibration.
Neo is offline
Old 01-06-05, 03:03 PM
gs300man
gs300man's Avatar
You should have done your homework better. The lug nuts for the LS are different then the lug nuts for your GS. Someone must of felt dumb.
gs300man is offline
Old 01-06-05, 03:38 PM
NT2SHBBY
NT2SHBBY's Avatar
actually no newb.....I don't feel dumb because I sold em EXACTLY for what I paid for em......
NT2SHBBY is offline
Old 01-06-05, 03:57 PM
chuckb
chuckb's Avatar
lol tell him N2. He dedicated his first post to dissin you I knew that would get something out of ya
chuckb is offline
Quick Reply: These wheels would look good on a GS?
