How do you remove speedo cluster?
Does anyone know how to remove the speedo cluster on a 2001 gs430? I found a thread with step by step pictures for the sc - but it seems to be different. than the gs.
Originally Posted by rgarjr
Pretty easy..
Grab a hold of the cluster and pull it straight towards you. Then disconnect the connector. They are a couple of bolts that you need to take out on the cluster unit. Then pull the cluster towards you and disconnect some connectors on the rear.
yup...if i can do it , anyone can..lol
Guys - you disconnect the bolts before pulling the cluster out?? If so, I can't find where the bolts are! Also, where do you grab the cluster? There doesn't seem to be a good way to get ahold of it.
Thanks
Thanks
Cool - got it out just as you guys described!
Now anyone know how I can get the factory radio and climate control out? Again - i've only been able to find for sc.
spinedoc
10-18-01 08:08 AM
