where can I get blue lights for my climate/radio?
Keeper of the light
The GS's looked great: http://lextech.org/gallery/thumbnails.php?album=1
.....but the ambient light sensor screwed with the cathode changeover and the system simply didn't work. It's a tricky little system that is likely never going to be "correct" in an aftermarket install. If it's not done right LLS doesn't put it out, so...... no go from lextech. It was determined that the stock system needed too much re-designing to make it happen.
Some might can deal with half assing as long as it is blue, or white, or whatever color someone likes, but if it is (a) in a Lexus and/or (b) from LLS it's either going to be done right, or not at all from where I stood when I was part of the design team in '03,04,05.
If someone get's it absolutely correct and working perfectly just like stock...... they deserve to produce them.
I read somewhere on another site that u use the same bulb thats used for the key hole light...u need like 8 of them. u can get them from lexstasy. i just need help gettin to the bulbs to replace them. Is there a way to get to the bulbs behind the radio climate???
greenRX300
RX - 1st Gen (1999-2003)
08-15-13 08:27 AM
