anyone knows if I couls install the tte front lip spoiler by myself
I'm planing to buy the tte front lip spoiler and want to install it myself.
Anyone have any suggestion or know how to install the tte front lip spoiler.
Is it easy to do ?
Is it easy to do ?
Forum Administrator
It comes unpainted unless you've made special arrangements, so don't forget that step.
installing of the lip is like butter but you do need 3 people pref 2 would work though.. i have done 4 of them already in my garage.. prep work is the key.. firstly the lip has to be pliable so you will need to leave in the sun for a hour or 2 to get flexible, then test mount and go for a snug fit, use a wax pencil and trace the top edge all around the top of the lip to where it meets the bumper to establish a sanding line ..remove lip and sand below that line , use mineral spirits to clean up residue after sanding , then sand along inner edge of lip and clean up residue there as well with mineral spirits.. as far as adhesive , in all 4 cases i did not use the cheap garbage tte sends , i use a ureth to ureth bonding sealant which glass installers use to adhere windshields for when that cures theres no turning back.(my lip has been mounted for almost 2 yrs in the south florida heat ) squeeze a bead of the good stuff along the inner edge of the lip from end to end , get your screws together and make sure you have plenty of paper towels and mineral spirits ready for when you mount a small amount odf adhesive will ooze and you want to wipe that up well before drying time sets in,, the rest is self expla in terms of the screws
thats really about it , now after mounting the car needs to be in a garage overnight to cure and you need to prop up the lip with just enough pressure to aide in the bonding and curing process( i sed my floor jace with a piece of 2x4 wrapped in a towel to get the front snug then telephone books at each corner to prop up and then get the blue painters masking tape and tape up all around the the bottom of the lip to the hood of the car to also help keep the pressure on , thats the key to a snug fit and a complete seal /bond between lip and bumper
Originally Posted by LEXUS_KID
Just drive down to Florida and give Lexforlife a call. He seems like a pro at this one.
as far as pro i would not go that far but mine has seemed to hold up well in this florida 100 deg heat since 6/03 when installed by me i just like doing things for myself
heres a closeup of mine photo taken this month
Originally Posted by rominl
yup i agree. i would imagine 3 people to be the best, one front, and two on each side. the front has to hold the front adhesive and push it up, and the two sides push it up too. you want it to be on very tight
3 people to install the TTE lip????? my god...you guys are spoiled. 1 person is enough =P
