Need help with audio harness??
Sorry, I know this is in the wrong area but I need help find a audio harness for a 2000 GS. Me and my friend are trying to hook my aftermarket head unit, but the pin configuration on the harness is different from the stock harness.
We need to find the diagram in order to located the right pins in the right area. Thank You very much!!
Ok, I found out the info for some of the pins. We found out about constant, accessory, and ground which are all easy.
However, we are having a huge problem find the pin config and colors for all the speakers, power ant, and remote? Can someone please help finding the color for there wires????????
I've been searching for hours and I can't seem to find the right info.
Thank YOU!!
Thank YOU!!
hey guys i did a little research and came up with more questions!!
This whole time I was under the impression that I can bypass my pre-amp system with my alpine head unit. I was trying to find the diagram so I can match up the pins in order to do this. However, I was told that I would have to rewire the pre-amp system and just run the speakers from my head unit.
Is this correct??
Can someone please help me find out what is the best way to do this. I really want to keep the factory speakers and the harness, so that I can put my car back to stock without any headaches.
Thanks.
Is this correct??
Thanks.
Originally Posted by audio28
Thanks for all the help and the info. I will try to write up a diy when I do the install. Hopefully it will work. I greatly appreciate everything.
