Fog Light / Parking light
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
Does anyone knows how to hookup the Fog light to Parking Light (meaning turn on parking light only and the fog light will also lights up). I try additional wire and attach both fog light wire and parking light wire together, it works for a day but it burn the fuse eventually. Please help me if anyone have done this before and works. thanks
GS has foglights. So a switch and the logic required when to turn on the fog lights is already built-in. With High beams on the foggies turn off.
If you add additional foglamp, I would also recommend get a relay. The relay can be activated by tapping into the existing fog-lamps 12V line. Make sure you add a fuse to the new line Battery -> fuse -> relay (switch) -> New Foggies -> GND.
Just in case it was not clear the actuating side of the relay ..
12V switched existing fog lamp tap -> sense terminal of relay -> gnd.
Salim.
Salim.
Copout221
11-06-02 01:16 AM
