need help to install ltuned sideskirt
#31
Ok he emailed me and said he sent the clips but he said there are no instructions to give me ![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
I planned on installing myself as i install most of my mods by myself so any instructions on install will help!!!
Thanks
Thanks
#32
Thanks
Thanks
#33
Thanks
Thanks
#34
i want to make sure the snow has slowed down or that it has stopped completely b4 i install it, i will print the instructions out until then so they'll be on hand!
Thanks!
P.s. i "WISH" if i did get stuck a CT CL member would help but i dont know anyone!
Thanks!
#35
Thanks!
P.s. i "WISH" if i did get stuck a CT CL member would help but i dont know anyone!![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Thanks!
#36
The hardest part of it was trying to take the oem skirts off. Those clips were tough to break! Or maybe I'm just weak.
Btw, did anyone find a lot of dirt under their plastic side trim moldings?
#37
Yes there was a lot of dirt, a good place for a little rust to get started. I washed all the dirt off before installing the new sideskirts. Did anyone have trouble putting the front two clips back in without them just falling out.
#38
#39
Just got done putting in the sideskirts and ran into the same issue you guys had. On my car I got all but the front clips on both sides in. I don't know that it's the clips being too small because the factory ones are the same. To me it looks like the hole is off from where it should be keeping the clip from going in all the way.
For those that are going to do this, I would start with the outter clip front and back and work your way to the middle, that might help. The other problem on mine was that the mounting tab on the front of both skirts was too small to let the white clip snap in. I had bought extra white clips ahead of time and tried to put them through the tab but those too did not fit. Don't know if anyone else had this problem but my skirts had to be painted so maybe the extra layer of paint caused this?
#41
Originally Posted by GSLofquist
could you post some pics of the completed install?
#44
Originally Posted by flossn
Pics are uploaded!! I put them on a new thread so you will want to check for them if you haven't seen them already
#45
bringing this thing back from 05'
FINALLY got my ltuned sides from GS300TOM installed. what other aftermarket retainer clips can we use?? i went to autozone and none of them really fit properly or secure enough. i got the biggest one there which is a GM one but they fall right out with a little light pull unlike the old lexus ones which has a little anchor built on the sides which held on for dear life.
i know they sell it at sewell but the shipping price cost more than the actual product and i dont really need anything from them for the meantime so i was just checking to see if there are any other alternatives?
thanks!
these are the ones i got from autozone.
thanks!
marcoes300
03-16-11 05:25 PM
kevs98GS4
03-25-08 11:23 AM
