Trunk Slams-Can you adjust springs?
My 2001 GS 300 has an after market spoiler on it, least I assume it does.
As a result the trunk springs are not strong enough to lift it when you click the opener, or to stop it slamming unless you really pay attention when closing. Can the spring tension be adjusted and how do I get the trunk trim at the sides out. Can't seem to get the black push pins out without using too much force and trashing them. Tx Machog
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Hey Machog did you try search this time? For something like 'trunk slams' in the GS forum?
Forum Administrator
If you looked for those keywords, you'd find the following threads
https://www.clublexus.com/forums/sho...ht=trunk+slams
The first one leads you to exactly what you're looking for.
https://www.clublexus.com/forums/sho...threadid=29600
Catching the hint, please use search before posting
- most every question you ask is going to be out there already.
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
As a result the trunk springs are not strong enough to lift it when you click the opener, or to stop it slamming unless you really pay attention when closing. Can the spring tension be adjusted and how do I get the trunk trim at the sides out. Can't seem to get the black push pins out without using too much force and trashing them. Tx Machog![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Just so you know, you can order stiffer springs from the dealer. The GSs that came with the spoiler/wing from the factory also came with stronger springs. Just order the trunk spring for a GS with a spoiler. I hope this helps.
Will
Originally Posted by TAMR_GUS98
Hey Fellas,
Will
Will
The One
Originally Posted by rominl
and there is also an intall kit that you should purchase at the same time too, otherwise installing the springs with such force would be too dangerous
Originally Posted by Neo
Install kit? I did not use any kit when I swapped mine out. I don't know what is in the kit but I did not feel I needed one. It's a good thing since I did not have the kit. ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Both trunk springs were in their "stiffest" position when I checked, but trunk still slams. Have it at the dealer for some other warranty work-so they are going to look at other cures. Will post if they cure it. Machog.
The One
Read the post, thought about our trunks and they way they closed. Almost scary because you thought it may close on you sometimes because of the lack of tension. The decks almost seemed heavy.
So, I grabbed the pliars and screw driver and readjusted both of our trunks. Much, much better. Now I am not fearful of the kids getting their hands or fingers bitten.
Doug
PS-took 15 minutes for both cars
Doug
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Doug
PS-took 15 minutes for both cars![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Doug
For those who have the spring tension maxed out, here is the after market part info for the stronger springs. www.lexusparts.com can get them for;
Shopping Cart
Qty Description
Unit Price
Amount
6453230261-Spring, w/Spoiler ea $25.35 $25.35
To cancel a specific item, enter "0" for quantity
& select UPDATE ORDER. SUBTOTAL $25.35
Lexus dealer charges $40.00, plus install if not under warranty. Machog
Shopping Cart
Qty Description
Unit Price
Amount
