My enging lights on ?? help
My engine light came on like 3 days after i got my intake....does any one y ?? is it the intake or something else.. if it is the intake what can i do?????
While I was doing research on this RS Akimoto Intake, I stumbled across a few posts on the internet of other cars having the same problems where the check engine light comes on. My guess is that it is the intake that is causing the check enigine light to come on...Sorry Hope this helps.
Brent
Brent
Did you reset the ECU after you put your intake in? You can pull your negative battery cable for a few min and it will reset it for you. It will also clear the codes.
