Please post pics of your grounding kits!
#46
Originally Posted by Intellexual
Honestly, from the pictures I just see a lot of wires....it's hard to tell where one starts and another begins.
Also, I don't agree that the terminals have to be soldered, stock wiring is almost always crimped. If you have a good crimper, that connection can be as good or even superior to a soldered connection in terms of longevity.
#47
Originally Posted by CLS2GS300
I agree, I don't believe it is always necessary to solder. If you want good connections then try compression fit terminals.
How will a compression fit minimize corrosive effects over time the way that soldering would? The copper strands are still exposed to the elements in this condition and are not shielded from air & water as they would be if the copper wire was encapsulated by the solder.
This is all about reducing corrosive effects and the resulting increased resistance that the wire will bear over time. The physical strength of the connection is not my concern.
Anyone who has found a copper penny that was exposed to the elements over time can see that the integrity of copper is greatly compromised without protection, especially in the areas where good electrical contact and conductivity are the requirement.
My rational is no different than the practice of keeping battery terminals clean or sanding the ground areas for good electrical contact.
The performance of a crimped connection versus a soldered connection will be essentially the same in the beginning, but depending on your cars exposure to a salt environment (sea or snow) there's going to be a degredation over time which you will not be able to tell the loss because of it being a gradual affect.
Checking your cable to see if it is dark / blackish or even green is a sure sign of degredation.
This grounding mod has little if any effect on the performance of your car, so if you just crimp the connections, it's kind of pointless.
#48
I guess I'm the only one that caught this. Not a good idea. Excellent way to start a fire or blow all your fuses.
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
#50
Question for the people who installed a ground kit.
If you search the sounddomain forums there is a sticky regarding ground wires (Big 3). They suggest people put a fuse between the +battery and the alternator.
My question is this. Do the kits people here purchased take this into consideration?
Thanks,
Ed
Thanks,
Ed
#53
Guys,
I did this on my SC400 with the techkit. Didn't notice any difference whatsoever and I think it looked pretty bad also.
As for mounting points - it really doesn't matter!!! You can ground whatever the hell you want to ground!! Choose the major electrical things on your engine bay and run a ground to your chassis. Eg. put one on each side of your intake manifold to chassis.
You are not going to hurt anything by grounding it.
I ended up using self-tapping screws to go into some parts of the chassis because the bolts were no long enough.
Jonny
Jonny
nanotech
07-28-01 09:14 PM
