sunroof shade rattle fix
#61
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
Have a 2003 ES 300. All of a sudden my sunroof does not have the one touch operation, you have to hold the button.....Also have an intermittant problem with the passenger front dood power window, it will not always work....Have to get the car back to the dealer, but i am concerned about the sunroof...Thanks in advance!!!
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
#62
#64
bringing this back from the dead.
i found some sticky foam window seal insulation. that comes in a thin roll... is this appropriate? if so, which side should i be sticking to?
#65
don't mean to hijack the thread but I have this gremlin in my sunroof that prevents it from closing... i have to 'tilt' it open the second it closes. any ideas? and no i'm not going to the dlr.
#66
Well, add me to the list of someone who now has the dreaded clicking/tapping sound. It's definitely the sunshade because the noise goes away when I press up on the shade.
Henry, here's the part I don't understand. In order, from bottom to top, you have the headliner, the rail, and the sunshade. Does the foam go between the headliner and the rail or between the rail and the sunshade? I'm guessing it goes between the rail and the sunshade, but I can't tell from this picture:
https://www.clublexus.com/gallery/da..._4801_copy.jpg
Also, assuming it goes between the rail and the sunshade, how is it that the foam moves with the sunshade as you open and close it?
e
e
#69
e
#71
i read this on the hidden features thread. if u press the open sunroof button after it has fully opened, it will slide back a tiny bit more. it tightens up the slack and stops the tapping sound. worked for original poster and myself
#72
e
#73
Hey guys. Here's what I used and it works very well. I used a 4-5 inch strip on each side. Just pull the sunshade all the way back, cut the molding to size, and slide it over the guide rail that sits just beneath the sunshade. The only problem is that because the strip has a slight adhesive on the inside, it doesn't slide on the rail when you pull the sunshade forward. And actually, because of the notches towards the front of the sunshade, the strips will fall off when you try to close the sunshade. I keep my sunshade open at all times, so this really isn't a problem for me. Ideally, if you can cut a small strip of this, clean out the adhesive, and position it between the notches described by Henry above, it would work perfectly. Hope this helps.
e
EDIT: I'm thinking I might try using a smaller piece and positioning it between the notches on the sunshade (when you look at it, you'll know what I'm talking about). However, instead of sliding the strip onto the rail, I may just put the entire strip above the rail. This way, the adhesive won't be in contact with the rail and I think it will slide along with the sunshade. Does this make sense?
e
#75
This is what I was talking about above. Ideally, I'd like to position a smaller piece of molding either on the rail or above the rail between these two notches on the sunshade. Unfortunately, because of the adhesive on the molding strip, it won't slide with the sunshade and just falls off:
