Nakamichi Pins/Wire Colors
I'm either not good at searching, or this is a big secret -
I'm putting an aftermarket Pioneer TV HU into my 1999 GS400 (with Nakamichi), but can't find a pin out anywhere, although people have mentioned it does exist. I want to use the factory Nak amps and all, so I only need splicing info for the dash connections.
Can someone help me out with wire colors for -
Front - Left, Right outputs
Rear - Left, Right outputs
Sub output
12v+
Acc
Ground
Remote on (or whatever is used by the Nak system to turn on the amps in the trunk)
Sub output
12v+
Acc
Ground
Sub output
12v+
Acc
Ground
Sub output
12v+
Acc
Ground
Nicola, if possible please list your wire color finding.. All findings, if possible...
Im also about to install a Clarion vrx935vd and this would cut my research time in half..
VSsc400
04-26-04 06:54 AM
